Hello
Has anyone managed to get the keys from player.pl using WKS?
From what I have seen, no tokoen is required.
If you do not want the way to be public, write to priv
No headers needed, just PSSH and License url.
You can use this code instead of l3.py
Eme logger gives the long PSSH which I decode to file using base64.guru site, then I copy the hex starting from the 3 sets of zeroes that match the last mention of pssh, then I use that hex to convert to base64 to get the correct PSSH.Code:import base64, requests, sys, xmltodict from pywidevine.L3.cdm import cdm, deviceconfig from base64 import b64encode from pywidevine.L3.getPSSH import get_pssh from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt pssh = input('\nPSSH: ') lic_url = input('License URL: ') headers = { } def WV_Function(pssh, lic_url, cert_b64=None): wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic) widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers) license_b64 = b64encode(widevine_license.content) wvdecrypt.update_license(license_b64) print(widevine_license.content) Correct, keyswvdecrypt = wvdecrypt.start_process() if Correct: return Correct, keyswvdecrypt correct, keys = WV_Function(pssh, lic_url) print() for key in keys: print('--key ' + key) -
Indeed what vegeta says is correct, you can also get the KID from the .mpd and generate the correct psh with https://tools.axinom.com
WKS-Canal +
By staszek1503 in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Aug 2022, 16:20 -
need help with wks-keys
By ahmedani in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2022, 03:15 -
how to find wks-keys
By ahmedani in forum Video Streaming DownloadingReplies: 5Last Post: 12th Jul 2022, 13:56 -
Wks-keys
By Fjullekulle in forum Video Streaming DownloadingReplies: 10Last Post: 12th Jul 2022, 04:01 -
help wks-keys_v2
By ahmedani in forum Video Streaming DownloadingReplies: 3Last Post: 5th Jul 2022, 10:42
