I'm looking for a good subtitle editor for macOS. I've used Subtitle Edit on my previous Windows machine and would like to use something similar on macOS.
The tool should be able to convert SUP streams to SRT using OCR and convert SRT subtitles to SUP format.
Syncing a subtitle to another subtitle or to a video or audio stream would be a welcome addition.
There are quite a few subtitle apps available in the AppStore for which you have to pay. But from the reviews and description with the apps I find it hard to determine which one to purchase. You risk purchase a tool that doesn't work as well as you'd hoped and I'm not sure if I can get my money back when the tool isn't to my liking.
Thanks for your tips and pointers in advance.
Thread moved to the mac forum where you can get more help.
try looking in tools - subtitle editors - https://www.videohelp.com/software/sections/subtitle
there's 5 to choose from for mac. -
Thanks for pointing that out to me.
I've tried them all (for some I needed to use a beta version 'cause the 'release' version doesn't support the 64-bit M1 or M2 chips).
Unfortunately none of them support the opening/importing of blu-ray SUP format subtitles. In the Windows application I've used in the past (Subtitle Edit) I could open de SUP file in the editor and immediately the OCR process would kick in to convert the SUP image based subtitles to text.
The subtitle editors presented on the page you refer to will (almost) all are fair to good SRT file editors. But I need an application for my Mac that can take a SUP file and (interactively) convert is to SRT format...
Eztoosoft Video Subtitle Editor v2.01
By videohelper in forum SubtitleReplies: 4Last Post: 30th Aug 2022, 20:11 -
Easy Subtitle editor?
By magnu in forum EditingReplies: 2Last Post: 25th May 2022, 07:33 -
Any subtitle editor on Chrome OS?
By Hakunamatata67 in forum SubtitleReplies: 1Last Post: 2nd Jun 2021, 07:24 -
How to save files as .SUP from Subtitle Editor?
By DiodE in forum SubtitleReplies: 4Last Post: 14th Nov 2020, 06:21 -
subtitle editor - how to bridge gaps?
By _Lucky_Luka in forum SubtitleReplies: 6Last Post: 31st Jan 2018, 10:45
