Hi guys, I hope everyone is doing well.
I have a video file consisting of:
video
audio inglés
audio francés
28 subtítles
What I want is to copy the video, the two audios and the subtitles 1,2 and 10 with mkvmerge or similar, and if it is possible to create a bat batch file, I do not know if someone had the magic in his hands.
I appreciate any help, greetings.
[Attachment 66274 - Click to enlarge]
Use MkvToolnix for a single video.
Drag your file in the upper pane and select the streams you want in the lower pane.
A Batch for what?
Do you have hundreds of videos where you need exactly 1 video stream, 2 audio streams and subtitle streams 1,2 and 10? -
Thank you for answering, yes, although there are not many (20 files), it is annoying to do it one by one.
Something like this, but it didn't work for me, it's clear that I'm missing or missing something.
"C:\gram Files\MKVToolNix\mkvmerge.exe" --ui-language en --priority low --output ^"C:\Test ^(1^). mkv^" --subtitle-tracks 3,4,12 --language 0:en --display-dimensions 0:1920x1080 --language 1:en --language 2:en --sub-charset 3:UTF-8 --language 3:en --sub-charset 4:UTF-8 --language 4:en --sub-charset 12:UTF-8 --language 12:fr ^"^(^" ^"C:\Test. mkv^" ^"^)^" --track-order 0:0,0:1,0:2,0:3,0:4,0:12Last edited by gufoli; 13th Aug 2022 at 04:12.
Try
"C:\Program Files\MKVToolNix\mkvmerge.exe" --ui-language en --priority low --output "C:\Test(1). mkv" --subtitle-tracks 3,4,12 --language 0:en --display-dimensions 0:1920x1080 --language 1:en --language 2:en --sub-charset 3:UTF-8 --language 3:en --sub-charset 4:UTF-8 --language 4:en --sub-charset 12:UTF-8 --language 12:fr "(" "C:\Test.mkv" ")" --track-order 0:0,0:1,0:2,0:3,0:4,0:12 -
Mkvmerge, batch to mkvmerge add multiple audio tracks
By SrBills in forum Newbie / General discussionsReplies: 5Last Post: 15th Mar 2024, 12:03 -
Spreadsheet to aid batch muxing video and subtitles file in mkvmerge
By aspenx in forum Video ConversionReplies: 4Last Post: 16th Mar 2020, 13:16 -
MKVmerge
By tpapictures in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2019, 01:53 -
MKVmerge/MKVextract batch extract/muxing subtitles
By BuSHari in forum Newbie / General discussionsReplies: 2Last Post: 20th Oct 2017, 11:29 -
MKVmerge batch remuxing and removing subtitles?
By TE16 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2017, 07:55
