I attempted to burn a file with DVDFab software, but it appears that the software did not recognize the burner device. A window told me that “The directory name is invalid.” So, I checked This PC, and where the DVD RW E Drive should be, there is an F, and where the DVD RW F Drive should be, there is a G.
How do I return the drives to E & F?
Results 1 to 13 of 13
You don't say which OS you have.]
I can only tell you from Windows 7 & older.
Go to Administrator Tools/Computer Managememt/Storage/Disk Management
Scroll down to your CD ROM drives.
Right click on the Left box
You should see Change drive letter and paths.
Click it & change the drive letters back to where they were. -
Well Drive letters are normally issued sequentially so there must have been at some time a 'Drive E'. And if there is in existance a 'Drive E' then that would also have to be renamed.
I can only write about Win7 and it is achieved like this:
From Control Panel you select Administrative Tools > Computer Management > Disk Management
You now see two windows with all HDD's in the higher one and all drives in the lower. Scroll down the lower and you see the CD/DVD ROMs. A right-click on the Drive name gives you an option to change the Drive Letter.
But if these DVD drives are external, Drive Letters are allocated on-the-fly so even renaming Drive E to Drive H could well mean that F and G then become I and J.
But surely you can change settings in DVDFab to read/write to the correct letters ? -
I was able to change the drive letters, but when I went back to This PC to open the drives, it told me to please insert a disc.
It is not recognizing something.
Any ideas? -
We appear to be missing some info here. Maybe obvious but to avoid misunderstanding.
1. Does the drive you click on to open already have a disk inside ?
2. What happens if you try another blank disk ?
3. What happens if you try an already burnt or commercial disk ? -
Before I answer the questions, my apologies, I am attempting to copy a disc, not burn it.
Ok. But do read again what you originally wrote. The impression given was to do a direct copy/burn from one drive to another.
So 'copy' really means rip (to HDD ?) and all I am trying to establish is if it is the program that is at fault or your system (or even both) -
Are you actually missing the burner drive all together or is it not being recognized?It shouldn't matter if it moved to another letter.
Switch from AviUtil?
By ChasVideo in forum EditingReplies: 2Last Post: 24th May 2022, 19:51 -
DVD/BLU RAY Back-up --- Best Way to Watch Back on TV
By Ashthezombieasskicker in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2022, 20:34 -
Converting stretched/widescreen video back to original 4:3?
By kkeut in forum Video ConversionReplies: 12Last Post: 18th Sep 2021, 03:21 -
how to re-add original audio delay back into a 2-inputfile ffmpeg transcode
By hydra3333 in forum Newbie / General discussionsReplies: 0Last Post: 30th Jul 2020, 02:30 -
what do you call external usb drives that are not flash drives?
By oduodui in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2019, 13:21
