I've been tearing my hair out trying to do this.
I have an (interlaced) h264 stream that I've demuxed from an MKV file.
I've tried with: `vid=DirectShowSource("video.h264", audio=false)` but I just get:
I've tried the latest release of FFmpeg2Source, however that seems to just hang as soon as it tries to open seemingly any file.Code:DirectShowSource: couldn't open file video.h264 Cannot play back the file. The format is not supported.
What am I doing wrong?
FFMPEG proper gives me this:
Code:$ ffmpeg -i video.h264 ffmpeg version 4.3.1-2020-10-01-full_build-www.gyan.dev Copyright (c) 2000-2020 the FFmpeg developers built with gcc 10.2.0 (Rev3, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 [h264 @ 0000022a4f7cdc40] Stream #0: not enough frames to estimate rate; consider increasing probesize Input #0, h264, from 'video.h264': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (High), yuv420p(top first), 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 1200k tbn, 59.94 tbc
I'm not sure if any of the source filters work with the h264 elementary stream.
Any reason not to access it from the container? -
Thanks ProWo. Could have sworn I tried this earlier. I guess sometimes what we think we know is just phantoms ...
Cutting Open-GOP H264 videos properly
By andiandi in forum EditingReplies: 14Last Post: 7th Sep 2020, 10:38 -
10-bit to 8-bit Video File Conversions - the easy (free) way!
By VideoWiz in forum Video ConversionReplies: 10Last Post: 6th Feb 2020, 04:24 -
Upgrading Avisynth to 64-bit
By Aludin in forum Newbie / General discussionsReplies: 6Last Post: 16th Apr 2019, 17:48 -
Avisynth 64 Bit + LSMASHVideo 64 Bit
By kalemvar1 in forum Video ConversionReplies: 4Last Post: 12th Dec 2018, 04:49 -
Open file Error with Mkvmerge v20.0.0 ('I Am The Sun') 64-bit
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 3Last Post: 22nd Feb 2018, 04:47
