Hello!
I have been recording sports events off DVB/IPTV for last decade. Now I have been trimming out different clips in order to make highlights compilation later. My question is whether I should deinterlace them (with AviSynth) before feeding them to video editing software (Davinci Resolve) or not?
There are two types of videos and I have attached them to this post:
1) 576i SDTV (2010-2018)
2) 1080i HDTV (since 2018)
Results 1 to 10 of 10
I would always bob deinterlace interlaced content, before doing any further editing.
If interlaced output is needed I would (curse the reason that forces me to use interlacing and) just reeinterlace at the end of the filtering.
Cu SelurLast edited by Selur; 10th Aug 2022 at 11:45.
users currently on my ignore list: deadrats, Stears555 -
It depends on what you plan to do with the video and your final delivery format.
My final format would be:
576i -> 720p 16:9
1080i -> 1080p 16:9
All of them would be for later usage in Youtube, Facebook etc. -
Originally Posted by Jagabo
I haven't done any filtering in VirtualDub in many years. So I don't know if there's any significant difference between AviSynth Yadif and VirtualDub Yadif. I hardly use Yadif anyway. Just occasionally when I'm working on some other slow filters and want to speed up the processing. I'll usually switch to QTGMC for the final processing.
Yes, bwdif is better than yadif and about the same speed. bwdif doesn't leave little "droppings" all over the picture.
convert recordings from a lg smart tv through pc need software to do it
By elm in forum Video ConversionReplies: 6Last Post: 27th Apr 2023, 06:36 -
Recording Panopto recordings with OBS (or some other SW)
By aurgathor in forum Video Streaming DownloadingReplies: 17Last Post: 8th Feb 2020, 18:35 -
dvr recordings
By fifalwt91 in forum CapturingReplies: 21Last Post: 10th Jan 2020, 19:59 -
Audio format for TV recordings
By Brasso27 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2019, 06:12 -
Extracting recordings from the Tosh RD-XS series
By jwillis84 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 10th Feb 2019, 18:39
