  1. Does anybody know if it is possible to script the addition of 1 second of black to the start of a video file whilst encoding via x264/ffmpeg?
    It would also be useful if there was a way of scripting chapter markers to the correct the right I-frame.
    Mar 2008
    Yes, create a simple AVIsynth script and encode in ffmpeg/Virtualdub2, etc. For example
    vid=lwlibavVideosource("S:\misc film\shorts\test.mp4")
    aud=lwlibavAudiosource("S:\misc film\shorts\test.mp4")
    audiodub(vid,aud)
    bc=blankclip(last,length=24)
    bc+last
  3. If the first frame of your video is black you can use ffmpeg's loop filter to repeat that first frame N (one second) times, and the adelay filter to delay the audio by the same amount of time (inserts silent audio). Assuming a 24 fps video:
    ffmpeg -i input.mp4 -vf loop=loop=24:size=1:start=0 -af adelay=1000:all=1 -c:v libx264 -c:a aac output.mp4
    The first frame is repeated 24 times (1 second); 1000 milliseconds of silent audio is inserted.
    https://ffmpeg.org/ffmpeg-filters.html#loop
    https://ffmpeg.org/ffmpeg-filters.html#adelay
  4. By the way, here's a mod of davexnet's AviSynth script which automatically generates the correct number of blank frames based on the video's frame rate (rather than manually specifying the number of frames):
    audiodub(vid,aud)
    BlankClip(last, length=round(framerate))+last
    If you wanted a different length of time, say 1.5 seconds, just multiply the framerate by that amount:
    BlankClip(last, length=round(framerate*1.5))+last
  5. Thanks for the suggestions, will give them a try out.
