dupe
Results 31 to 35 of 35
users currently on my ignore list: deadrats, Stears555, marcorocchini -
adding -strinc -2 does seem to help somewhat:
Code:ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -strict -2 -pix_fmt yuv422p -map 0:0 -an -sn -vf format=yuv422p,scale=1440:1080,zscale=rangein=tv:range=tv,colormatrix=bt601:bt709,scale,format=yuv422p -vsync 0 -sws_flags spline -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -flags +ildct+ilme -top 0 "E:\Output\test.mov"
Code:Video ID : 1 Format : VC-3 Commercial name : DNxHD 220 Format version : Version 1 Format profile : HD@ Codec ID : AVdn Codec ID/Info : Avid DNxHD Duration : 2 s 2 ms Bit rate mode : Constant Bit rate : 200 Mb/s Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 4:3 Original display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Original frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First
yup, not sure why this is happening,... will do more testing this evening.
It's broken, that's why
If you really, really need it you can download the official codecs from Avid for free and an old version of quicktime to export it . I think mpegstreamclip should work too
FFmpeg vs official decoders question
By PU User in forum Video ConversionReplies: 1Last Post: 30th Apr 2022, 10:50 -
Apple dropping codecs including Cineform, DNxHD
By ConsumerDV in forum Latest Video NewsReplies: 1Last Post: 22nd Apr 2022, 04:52 -
Some question about FFMPEG
By kucing in forum Newbie / General discussionsReplies: 2Last Post: 28th Aug 2021, 16:53 -
Size problem with DNxHD
By akkers in forum Video ConversionReplies: 4Last Post: 25th Dec 2019, 05:26 -
cant export to dnxhd in blender
By oduodui in forum EditingReplies: 4Last Post: 14th Jun 2019, 19:52
