I wanted to use:
and got:Code:ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -map 0:0 -an -sn -vf scale=1440:1080,zscale=rangein=tv:range=tv,setfield=bff -pix_fmt yuv422p -vsync 0 -sws_flags spline -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -flags +ildct+ilme "E:\Temp\interleaved_2022-08-06@16_39_46_2510_01.mov"
Which confuses me, since I was aiming for "Frame size: 1440x1080i; bitrate: 100Mbps; pixel format: yuv422p" and thought that:Code:ffmpeg version N-107415-gcb7b2b1f73-g4136405c86+1 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 12.1.0 (Rev3, Built by MSYS2 project) configuration: --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads libavutil 57. 29.100 / 57. 29.100 libavcodec 59. 38.100 / 59. 38.100 libavformat 59. 28.100 / 59. 28.100 libavdevice 59. 8.100 / 59. 8.100 libavfilter 8. 45.100 / 8. 45.100 libswscale 6. 8.100 / 6. 8.100 libswresample 4. 8.100 / 4. 8.100 libpostproc 56. 7.100 / 56. 7.100 -vsync is deprecated. Use -fps_mode Passing a number to -vsync is deprecated, use a string argument as described in the manual. Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Selur\Desktop\input.mov': Metadata: major_brand : qt minor_version : 537199360 compatible_brands: qt creation_time : 2022-08-05T21:03:59.000000Z Duration: 00:00:02.00, start: 0.000000, bitrate: 226275 kb/s Stream #0:0[0x1](eng): Video: v210 (v210 / 0x30313276), yuv422p10le(smpte170m/smpte170m/bt709, bottom coded first (swapped)), 720x486, 223725 kb/s, SAR 10:11 DAR 400:297, 29.97 fps, 29.97 tbr, 30k tbn (default) Metadata: creation_time : 2022-08-05T21:03:59.000000Z handler_name : Apple Video Media Handler vendor_id : KeyG encoder : Uncompressed 10-Bit YUV timecode : 00:00:00;00 Stream #0:1[0x2](eng): Audio: pcm_s24le (in24 / 0x34326E69), 48000 Hz, stereo, s32 (24 bit), 2304 kb/s (default) Metadata: creation_time : 2022-08-05T21:03:59.000000Z handler_name : Apple Sound Media Handler vendor_id : [0][0][0][0] timecode : 00:00:00;00 Stream #0:2[0x3](eng): Data: none (tmcd / 0x64636D74), 0 kb/s (default) Metadata: creation_time : 2022-08-05T21:03:59.000000Z handler_name : Time Code Media Handler reel_name : 001 timecode : 00:00:00;00 Stream mapping: Stream #0:0 -> #0:0 (v210 (native) -> dnxhd (native)) [dnxhd @ 000001da83a36340] Profile selected is experimental [dnxhd @ 000001da83a36340] video parameters incompatible with DNxHD. Valid DNxHD profiles: [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 175Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 185Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 365Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 440Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 115Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 240Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 290Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 175Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 185Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 220Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 365Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 440Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080i; bitrate: 185Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080i; bitrate: 220Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080i; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080i; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080i; bitrate: 185Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080i; bitrate: 220Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080i; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080i; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 90Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 180Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 220Mbps; pixel format: yuv422p10 [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 90Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 110Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 180Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 220Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 60Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 75Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1280x720p; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 36Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 45Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 75Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 90Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 350Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 390Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 440Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 730Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 000001da83a36340] Frame size: 1920x1080p; bitrate: 880Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 000001da83a36340] Frame size: 960x720p; bitrate: 42Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 960x720p; bitrate: 60Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 960x720p; bitrate: 75Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 960x720p; bitrate: 115Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080p; bitrate: 63Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080p; bitrate: 84Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080p; bitrate: 100Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080p; bitrate: 110Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080i; bitrate: 80Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080i; bitrate: 90Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080i; bitrate: 100Mbps; pixel format: yuv422p [dnxhd @ 000001da83a36340] Frame size: 1440x1080i; bitrate: 110Mbps; pixel format: yuv422p [dnxhd @ 000001786f677580] ff_frame_thread_encoder_init failed Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height Conversion failed!
should make sure that resolution, scantype, bitrate and pixel format are correct.Code:-vf scale=1440:1080,zscale=rangein=tv:range=tv,setfield=bff -pix_fmt yuv422p -vsync 0 -sws_flags spline -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -flags +ildct+ilme
=> Does anyone see where I went wrong?
Cu Selur
Results 1 to 30 of 35
Try without +ilme
https://lists.ffmpeg.org/pipermail/ffmpeg-user/2015-June/027187.html -
@Cornucopia:
using:
and then:Code:ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -map 0:0 -an -sn -vf scale=1440:1080,zscale=rangein=tv:range=tv,setfield=bff -pix_fmt yuv422p -vsync 0 -sws_flags spline -flags +ildct+ilme "E:\Output\test.y4m"
throws the same error, but using (without '-flags +ildct+ilme')Code:ffmpeg -y -noautorotate -nostdin -threads 8 -i "E:\Output\test.y4m" -vf zscale=rangein=tv:range=tv,setfield=bff -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -pix_fmt yuv422p -vsync 0 -sws_flags spline -flags +ildct+ilme "E:\Output\test.mov"
does not crash, but produces progressive output. :/Code:ffmpeg -y -noautorotate -nostdin -threads 8 -i "E:\Output\test.y4m" -vf zscale=rangein=tv:range=tv,setfield=bff -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -pix_fmt yuv422p -vsync 0 -sws_flags spline "E:\Output\test.mov"
using, same for (moved -flags +ildct+ilme)
@ProWo: using:Code:ffmpeg -y -noautorotate -nostdin -threads 8 -flags +ildct+ilme -i "E:\Output\test.y4m" -vf zscale=rangein=tv:range=tv,setfield=bff -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -pix_fmt yuv422p -vsync 0 -sws_flags spline "E:\Output\test.mov"
(-flags +ildct)Code:ffmpeg -y -noautorotate -nostdin -threads 8 -i "E:\Output\test.y4m" -vf zscale=rangein=tv:range=tv,setfield=bff -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -pix_fmt yuv422p -vsync 0 -sws_flags spline -flags +ildct "E:\Output\test.mov"
throws the same error.
Hmm,.. looking at the y4m the scan type seems wrong.
attached the input.mov (all black frames) I used.Code:I:\Hybrid\64bit>mediainfo.exe e:\Output\test.y4m General Complete name : e:\Output\test.y4m Format : YUV4MPEG2 File size : 178 MiB Duration : 2 s 2 ms Overall bit rate : 746 Mb/s Video Format : YUV Duration : 2 s 2 ms Bit rate : 746 Mb/s Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 4:3 Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Scan type : Progressive Scan order : Bottom Field First Compression mode : Lossless Bits/(Pixel*Frame) : 16.000 Stream size : 178 MiB (100%)
users currently on my ignore list: deadrats, Stears555, marcorocchini -
try changing pix_fmt yuv422p to -pix_fmt yuv420p and see if it works - https://www.reddit.com/r/ffmpeg/comments/jc8461/ffmpeg_errors_out_with_error_initializing_output/
try changing pix_fmt yuv422p to -pix_fmt yuv420p and see if it works - https://www.reddit.com/r/ffmpeg/comments/jc8461/ffmpeg_errors_out_with_error_initializing_output/throws the same errorCode:
ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -map 0:0 -an -sn -vf scale=1440:1080,zscale=rangein=tv:range=tv,setfield=bff -pix_fmt yuv420p -sws_flags spline -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -flags +ildct+ilme "E:\Temp\test.mov"
+which makes sense since yuv420p isn't in any of the supported settings that are listed.Code:Incompatible pixel format 'yuv420p' for codec 'dnxhd', auto-selecting format 'yuv422p'
using "scale=1440:1080:interl=1,zscale=rangein=tv:range= tv,setfield=bff,format=yuv422p,fps=30000/1001" didn't help either
Code:ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -map 0:0 -an -sn -vf scale=1440:1080:interl=1,zscale=rangein=tv:range=tv,setfield=bff,format=yuv422p,fps=30000/1001 -sws_flags spline -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -flags +ildct+ilme "E:\Temp\test.mov" -v debug ffmpeg version N-107415-gcb7b2b1f73-g4136405c86+1 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 12.1.0 (Rev3, Built by MSYS2 project) configuration: --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads libavutil 57. 29.100 / 57. 29.100 libavcodec 59. 38.100 / 59. 38.100 libavformat 59. 28.100 / 59. 28.100 libavdevice 59. 8.100 / 59. 8.100 libavfilter 8. 45.100 / 8. 45.100 libswscale 6. 8.100 / 6. 8.100 libswresample 4. 8.100 / 4. 8.100 libpostproc 56. 7.100 / 56. 7.100 Splitting the commandline. Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'. Reading option '-noautorotate' ... matched as option 'autorotate' (automatically insert correct rotate filters) with argument 0. Reading option '-nostdin' ... matched as option 'stdin' (enable or disable interaction on standard input) with argument 0. Reading option '-threads' ... matched as AVOption 'threads' with argument '8'. Reading option '-ignore_editlist' ... matched as AVOption 'ignore_editlist' with argument 'true'. Reading option '-i' ... matched as input url with argument 'C:\Users\Selur\Desktop\input.mov'. Reading option '-map' ... matched as option 'map' (set input stream mapping) with argument '0:0'. Reading option '-an' ... matched as option 'an' (disable audio) with argument '1'. Reading option '-sn' ... matched as option 'sn' (disable subtitle) with argument '1'. Reading option '-vf' ... matched as option 'vf' (set video filters) with argument 'scale=1440:1080:interl=1,zscale=rangein=tv:range=tv,setfield=bff,format=yuv422p,fps=30000/1001'. Reading option '-sws_flags' ... matched as AVOption 'sws_flags' with argument 'spline'. Reading option '-vcodec' ... matched as option 'vcodec' (force video codec ('copy' to copy stream)) with argument 'dnxhd'. Reading option '-profile:v' ... matched as option 'profile' (set profile) with argument '0'. Reading option '-b:v' ... matched as option 'b' (video bitrate (please use -b:v)) with argument '100M'. Reading option '-mbd' ... matched as AVOption 'mbd' with argument '2'. Reading option '-flags' ... matched as AVOption 'flags' with argument '+ildct+ilme'. Reading option 'E:\Temp\test.mov' ... matched as output url. Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'. Finished splitting the commandline. Parsing a group of options: global . Applying option y (overwrite output files) with argument 1. Applying option nostdin (enable or disable interaction on standard input) with argument 0. Applying option v (set logging level) with argument debug. Successfully parsed a group of options. Parsing a group of options: input url C:\Users\Selur\Desktop\input.mov. Applying option noautorotate (automatically insert correct rotate filters) with argument 0. Successfully parsed a group of options. Opening an input file: C:\Users\Selur\Desktop\input.mov. [NULL @ 0000021823663800] Opening 'C:\Users\Selur\Desktop\input.mov' for reading [file @ 0000021823663d80] Setting default whitelist 'file,crypto,data' [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021823663800] Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100 [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021823663800] ISO: File Type Major Brand: qt [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021823663800] Unknown dref type 0x73696c61 size 12 Last message repeated 2 times [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021823663800] Before avformat_find_stream_info() pos: 56625442 bytes read:71458 seeks:3 nb_streams:3 [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021823663800] Probe buffer size limit of 5000000 bytes reached [mov,mp4,m4a,3gp,3g2,mj2 @ 0000021823663800] After avformat_find_stream_info() pos: 5610752 bytes read:5678114 seeks:4 frames:7 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Users\Selur\Desktop\input.mov': Metadata: major_brand : qt minor_version : 537199360 compatible_brands: qt creation_time : 2022-08-05T21:03:59.000000Z Duration: 00:00:02.00, start: 0.000000, bitrate: 226275 kb/s Stream #0:0[0x1](eng), 6, 1/30000: Video: v210, 1 reference frame (v210 / 0x30313276), yuv422p10le(smpte170m/smpte170m/bt709, bottom coded first (swapped)), 720x486, 0/1, 223725 kb/s, SAR 10:11 DAR 400:297, 29.97 fps, 29.97 tbr, 30k tbn (default) Metadata: creation_time : 2022-08-05T21:03:59.000000Z handler_name : Apple Video Media Handler vendor_id : KeyG encoder : Uncompressed 10-Bit YUV timecode : 00:00:00;00 Stream #0:1[0x2](eng), 0, 1/48000: Audio: pcm_s24le (in24 / 0x34326E69), 48000 Hz, stereo, s32 (24 bit), 2304 kb/s (default) Metadata: creation_time : 2022-08-05T21:03:59.000000Z handler_name : Apple Sound Media Handler vendor_id : [0][0][0][0] timecode : 00:00:00;00 Stream #0:2[0x3](eng), 1, 1/30000: Data: none (tmcd / 0x64636D74), 0/1, 0 kb/s (default) Metadata: creation_time : 2022-08-05T21:03:59.000000Z handler_name : Time Code Media Handler reel_name : 001 timecode : 00:00:00;00 Successfully opened the file. Parsing a group of options: output url E:\Temp\test.mov. Applying option map (set input stream mapping) with argument 0:0. Applying option an (disable audio) with argument 1. Applying option sn (disable subtitle) with argument 1. Applying option vf (set video filters) with argument scale=1440:1080:interl=1,zscale=rangein=tv:range=tv,setfield=bff,format=yuv422p,fps=30000/1001. Applying option vcodec (force video codec ('copy' to copy stream)) with argument dnxhd. Applying option profile:v (set profile) with argument 0. Applying option b:v (video bitrate (please use -b:v)) with argument 100M. Successfully parsed a group of options. Opening an output file: E:\Temp\test.mov. [file @ 0000021823a349c0] Setting default whitelist 'file,crypto,data' Successfully opened the file. Stream mapping: Stream #0:0 -> #0:0 (v210 (native) -> dnxhd (native)) cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream) Last message repeated 8 times detected 32 logical cores [Parsed_scale_0 @ 0000021821d27c80] Setting 'w' to value '1440' [Parsed_scale_0 @ 0000021821d27c80] Setting 'h' to value '1080' [Parsed_scale_0 @ 0000021821d27c80] Setting 'interl' to value '1' [Parsed_scale_0 @ 0000021821d27c80] Setting 'sws_flags' to value 'spline' [Parsed_scale_0 @ 0000021821d27c80] w:1440 h:1080 flags:'' interl:1 [Parsed_zscale_1 @ 0000021824a7fe80] Setting 'rangein' to value 'tv' [Parsed_zscale_1 @ 0000021824a7fe80] Setting 'range' to value 'tv' [Parsed_setfield_2 @ 000002182453e700] Setting 'mode' to value 'bff' [Parsed_format_3 @ 000002182453e9c0] Setting 'pix_fmts' to value 'yuv422p' [Parsed_fps_4 @ 000002182453ec80] Setting 'fps' to value '30000/1001' [graph 0 input from stream 0:0 @ 000002182453f000] Setting 'video_size' to value '720x486' [graph 0 input from stream 0:0 @ 000002182453f000] Setting 'pix_fmt' to value '64' [graph 0 input from stream 0:0 @ 000002182453f000] Setting 'time_base' to value '1/30000' [graph 0 input from stream 0:0 @ 000002182453f000] Setting 'pixel_aspect' to value '10/11' [graph 0 input from stream 0:0 @ 000002182453f000] Setting 'frame_rate' to value '30000/1001' [graph 0 input from stream 0:0 @ 000002182453f000] w:720 h:486 pixfmt:yuv422p10le tb:1/30000 fr:30000/1001 sar:10/11 [format @ 0000021824540580] Setting 'pix_fmts' to value 'yuv422p|yuv422p10le|yuv444p10le|gbrp10le' [AVFilterGraph @ 0000021824290a00] query_formats: 8 queried, 7 merged, 0 already done, 0 delayed [Parsed_scale_0 @ 0000021821d27c80] w:720 h:486 fmt:yuv422p10le sar:10/11 -> w:1440 h:1080 fmt:yuv422p10le sar:100/99 flags:0x0 [Parsed_fps_4 @ 000002182453ec80] fps=30000/1001 [Parsed_fps_4 @ 000002182453ec80] Read frame with in pts 0, out pts 0 cur_dts is invalid st:0 (0) [init:0 i_done:0 finish:0] (this is harmless if it occurs once at the start per stream) [Parsed_fps_4 @ 000002182453ec80] Read frame with in pts 1001, out pts 1 [Parsed_fps_4 @ 000002182453ec80] Set first pts to 0 [Parsed_fps_4 @ 000002182453ec80] Writing frame with pts 0 to pts 0 [dnxhd @ 0000021826dfd040] Profile selected is experimental [dnxhd @ 0000021826dfd040] video parameters incompatible with DNxHD. Valid DNxHD profiles: [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 175Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 185Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 365Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 440Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 115Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 240Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 290Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 175Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 185Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 220Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 365Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 440Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080i; bitrate: 185Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080i; bitrate: 220Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080i; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080i; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080i; bitrate: 185Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080i; bitrate: 220Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080i; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080i; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 90Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 180Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 220Mbps; pixel format: yuv422p10 [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 90Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 110Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 180Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 220Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 60Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 75Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 120Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1280x720p; bitrate: 145Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 36Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 45Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 75Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 90Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 350Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 390Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 440Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 730Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 0000021826dfd040] Frame size: 1920x1080p; bitrate: 880Mbps; pixel format: yuv444p10, gbrp10 [dnxhd @ 0000021826dfd040] Frame size: 960x720p; bitrate: 42Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 960x720p; bitrate: 60Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 960x720p; bitrate: 75Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 960x720p; bitrate: 115Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080p; bitrate: 63Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080p; bitrate: 84Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080p; bitrate: 100Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080p; bitrate: 110Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080i; bitrate: 80Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080i; bitrate: 90Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080i; bitrate: 100Mbps; pixel format: yuv422p [dnxhd @ 0000021826dfd040] Frame size: 1440x1080i; bitrate: 110Mbps; pixel format: yuv422p [dnxhd @ 0000021823918bc0] ff_frame_thread_encoder_init failed Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height [Parsed_fps_4 @ 000002182453ec80] Dropping frame with pts 1 [Parsed_fps_4 @ 000002182453ec80] 2 frames in, 1 frames out; 1 frames dropped, 0 frames duplicated. [AVIOContext @ 0000021823d21040] Statistics: 0 bytes written, 0 seeks, 0 writeouts [AVIOContext @ 000002182366bfc0] Statistics: 8479778 bytes read, 4 seeks Conversion failed!users currently on my ignore list: deadrats, Stears555, marcorocchini -
try adding -acodec copy -threads 12 https://stackoverflow.com/questions/13877031/error-while-opening-encoder-for-output-st...ect-parameters
I'm using '-an' which drops the audio,... replacing it with '-acodec copy -threads 12' doesn't change the error
adding '-top 0' doesn't help either.users currently on my ignore list: deadrats, Stears555, marcorocchini -
using:
(without the '-flags +ildct+ilme -top 0'-part)Code:ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -map 0:0 -an -sn -vcodec dnxhd -profile:v 0 -b:v 100M -vf scale=1440:1080,zscale=rangein=tv:range=tv,setfield=bff -pix_fmt yuv422p -vsync 0 -sws_flags spline "E:\Output\test.mov"
Produces proper DNxHD 100:
but how to produce 'DNxHD 100i' ?Code:Video ID : 1 Format : VC-3 Commercial name : DNxHD 100 Format version : Version 1 Format profile : HD@ Codec ID : AVdn Codec ID/Info : Avid DNxHD Duration : 2 s 2 ms Bit rate mode : Constant Bit rate : 100 Mb/s Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 4:3 Original display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 2.149 Stream size : 23.9 MiB (100%) Language : English Color primaries : BT.601 NTSC Transfer characteristics : BT.709 Matrix coefficients : BT.601
DNxHD 100i should be:
while DNxHD 100 is:Code:Frame size: 1440x1080i; bitrate: 100Mbps; pixel format: yuv422p
so the only difference should be whether the content is interlaced or not.Code:Frame size: 1440x1080p; bitrate: 100Mbps; pixel format: yuv422p
Cu Selur
Ps.: Also created a post over at doom9.Last edited by Selur; 6th Aug 2022 at 12:17.
You will likely want to test with an image that is alternating black & white rows to see how they're combined (or not). Since you're scaling as well, I would expect there to be some intermediate gray rows. But if it is now correctly flagging as interlaced, the only way to verify it truly is a proper interlaced output file is with an interlace-aware, dnxhd-supporting/expecting hardware player (camera?), or a pro NLE or other ingest system that does verification.
Scott -
It looks like the format is not being applied before being fed to dnxhd, not sure why
The last fmt should be yuv422p ; but instead it shows w:1440 h:1080 fmt:yuv422p10le
You can try moving format filter eariler in the filter chain[graph 0 input from stream 0:0 @ 000002182453f000] w:720 h:486 pixfmt:yuv422p10le tb:1/30000 fr:30000/1001 sar:10/11
[Parsed_fps_4 @ 000002182453ec80] fps=30000/1001 -
-> same errorCode:
ffmpeg -y -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -pix_fmt yuv422p -map 0:0 -an -sn -vf format=yuv422p,scale=1440:1080,zscale=rangein=tv:range=tv,setfield=bff -vsync 0 -sws_flags spline -vcodec dnxhd -profile:v 0 -b:v 100M -mbd 2 -flags +ildct+ilme "E:\Temp\interleaved_2022-08-06@16_39_46_2510_01.mov""
at this point I'm curious whether anyone can get one of the interlaced DNxHD profiles to work at all.
ffmbc works, but does not support 1440x1080
This test file was xdcam (1920x1080i25 4:2:2)ffmbc dnxhd encoding
[dnxhd @ 022151e0] available bitrates in Mb/s for 10bits:
[dnxhd @ 022151e0] 1080p24: 175
[dnxhd @ 022151e0] 1080p25: 185
[dnxhd @ 022151e0] 1080p30: 220
[dnxhd @ 022151e0] 1080p50: 365
[dnxhd @ 022151e0] 1080p60: 440
[dnxhd @ 022151e0] 1080i25: 185
[dnxhd @ 022151e0] 1080i30: 220
[dnxhd @ 022151e0] 720p24: 90
[dnxhd @ 022151e0] 720p25: 90
[dnxhd @ 022151e0] 720p30: 110
[dnxhd @ 022151e0] 720p50: 185
[dnxhd @ 022151e0] 720p60: 220
[dnxhd @ 022151e0] available bitrates in Mb/s for 8bits:
[dnxhd @ 022151e0] 1080p24: 36, 115, 175
[dnxhd @ 022151e0] 1080p25: 36, 120, 185
[dnxhd @ 022151e0] 1080p30: 45, 145, 220
[dnxhd @ 022151e0] 1080p50: 75, 240, 365
[dnxhd @ 022151e0] 1080p60: 90, 290, 440
[dnxhd @ 022151e0] 1080i25: 120, 185
[dnxhd @ 022151e0] 1080i30: 145, 220
[dnxhd @ 022151e0] 720p24: 60, 90
[dnxhd @ 022151e0] 720p25: 60, 90
[dnxhd @ 022151e0] 720p30: 75, 110
[dnxhd @ 022151e0] 720p50: 120, 185
[dnxhd @ 022151e0] 720p60: 145, 220
Code:ffmbc -i input.MXF -tff -vcodec dnxhd -b 120M -an ffmbc.mov
Format : VC-3
Commercial name : DNxHD 120
Format profile : HD@SQ
Codec ID : AVdn
Duration : 11 s 200 ms
Bit rate : 121 Mb/s
Width : 1 920 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 2.339
Stream size : 162 MiB (100%)
Language : English -
Thanks, that doesn't really help, but good to know.
This works ok with ffmpeg (~month old binary) for 1440x1080i25
But the Format profile field is weird
Format profile : HD@Code:ffmpeg -i input -vf setfield=tff,scale=1440:1080:interl=1 -b:v 120M -c:v dnxhd -flags +ildct+ilme -an dnxhd_25i_1440_120M.mov -y
The full raster version (not scaled to 1440x1080)has format profile filled inVideo
Format : VC-3
Codec ID : AVdn
Bit rate : 121 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 3.118
Color primaries : BT.709
Matrix coefficients : BT.709
Code:Video ID : 1 Format : VC-3 Commercial name : DNxHD 120 Format version : Version 1 Format profile : HD@SQ Codec ID : AVdn Codec ID/Info : Avid DNxHD Duration : 11 s 200 ms Bit rate mode : Constant Bit rate : 121 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 2.339 Stream size : 162 MiB (100%) Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
see if this tutorial will help - http://macilatthefront.blogspot.com/2018/12/tutorial-using-ffmpeg-for-dnxhddnxhr.html
@poisendeathray: Hmm,... will look into older ffmpeg builds.
@october262: don't see a difference to what I do
when using: "-vf zscale=rangein=tv:range=tv,setfield=bff,scale=1440 :1080:interl=1,format=yuv422p"
Code:ffmpeg -y -strict experimental -noautorotate -nostdin -threads 8 -ignore_editlist true -i "C:\Users\Selur\Desktop\input.mov" -map 0:0 -an -sn -b:v 100M -vf zscale=rangein=tv:range=tv,setfield=bff,scale=1440:1080:interl=1,format=yuv422p -fps_mode passthrough -sws_flags spline -mbd 2 -flags +ildct+ilme -top 0 -vcodec dnxhd -profile:v 0 "E:\Output\test.mov" -v debug
it seems better, but still fails.Code:[Parsed_zscale_0 @ 000002739b6da5c0] Setting 'rangein' to value 'tv' [Parsed_zscale_0 @ 000002739b6da5c0] Setting 'range' to value 'tv' [Parsed_setfield_1 @ 000002739b6d9fc0] Setting 'mode' to value 'bff' [Parsed_scale_2 @ 000002739b6d9a00] Setting 'w' to value '1440' [Parsed_scale_2 @ 000002739b6d9a00] Setting 'h' to value '1080' [Parsed_scale_2 @ 000002739b6d9a00] Setting 'interl' to value '1' [Parsed_scale_2 @ 000002739b6d9a00] Setting 'sws_flags' to value 'spline' [Parsed_scale_2 @ 000002739b6d9a00] w:1440 h:1080 flags:'' interl:1 [Parsed_format_3 @ 00000273989f7cc0] Setting 'pix_fmts' to value 'yuv422p' [graph 0 input from stream 0:0 @ 000002739b6dab80] Setting 'video_size' to value '720x486' [graph 0 input from stream 0:0 @ 000002739b6dab80] Setting 'pix_fmt' to value '64' [graph 0 input from stream 0:0 @ 000002739b6dab80] Setting 'time_base' to value '1/30000' [graph 0 input from stream 0:0 @ 000002739b6dab80] Setting 'pixel_aspect' to value '10/11' [graph 0 input from stream 0:0 @ 000002739b6dab80] Setting 'frame_rate' to value '30000/1001' [graph 0 input from stream 0:0 @ 000002739b6dab80] w:720 h:486 pixfmt:yuv422p10le tb:1/30000 fr:30000/1001 sar:10/11 [format @ 000002739b1a14c0] Setting 'pix_fmts' to value 'yuv422p|yuv422p10le|yuv444p10le|gbrp10le' [AVFilterGraph @ 000002739b0736c0] query_formats: 7 queried, 6 merged, 0 already done, 0 delayed [Parsed_scale_2 @ 000002739b6d9a00] w:720 h:486 fmt:yuv422p10le sar:10/11 -> w:1440 h:1080 fmt:yuv422p sar:100/99 flags:0x0
works ok using git master from today 56973eb687
maybe something in your source fille overriding some switch ?
That was 1920x1080i25 to 1920x1080i25 test . Fields are intact, chroma is good when examining fileFormat : VC-3
Codec ID : AVdn
Bit rate : 121 Mb/s
Color space : YUV
Bit depth : 8 bits
For "SD" to "HD" upscale, it should be using 709 (601 to 709), and TFF by convention; maybe some problem there ? -
@posinedeathray: Does 1440x1080i29.97 also work?
I doubt that the color matrix is the issue. (adding ',colormatrix=bt601:bt709' doesn't help)For "SD" to "HD" upscale, it should be using 709, and TFF by convention; maybe some problem there ?
Using 'setfield=tff' and '-top 1' doesn't help either.
Yes it does for 1440x1080i25 @120M. I didn't test 29.97. Same as the 1440 in post 17, with the format profile anomaly
Video
Format : VC-3
Codec ID : AVdn
Bit rate : 121 Mb/s
Color space : YUV
Bit depth : 8 bits
Matrix coefficients : BT.709 -
I created a bug entry for this over at https://trac.ffmpeg.org/ticket/9865, maybe someone from the ffmpeg dev team can answer this,.. (the https://en.wikipedia.org/wiki/List_of_Avid_DNxHD_resolutions also post that 29.97 should be legal)
It fails for 100M and 110M (even though they are listed), but works for 120M on my test file
You are right, 120M does work here too. (that probably is a workaround I could use for the file, but that 100M doesn't still seems like a bug)
That creates "DNxHD 145",...users currently on my ignore list: deadrats, Stears555, marcorocchini -
with 29.97fps
[dnxhd @ 000001f1e061abc0] Frame size: 1440x1080i; bitrate: 80Mbps; pixel format: yuv422p -> 80M -> doesn't work
[dnxhd @ 000001f1e061abc0] Frame size: 1440x1080i; bitrate: 90Mbps; pixel format: yuv422p -> 90M -> doesn't work
[dnxhd @ 000001f1e061abc0] Frame size: 1440x1080i; bitrate: 100Mbps; pixel format: yuv422p -> 100M -> doesn't work
[dnxhd @ 000001f1e061abc0] Frame size: 1440x1080i; bitrate: 110Mbps; pixel format: yuv422p -> 110M -> doesn't work
[dnxhd @ 000001b0867cf4c0] Frame size: 1440x1080i; bitrate: 120Mbps; pixel format: yuv422p -> 120M -> creates DNxHD 145
[dnxhd @ 000001b0867cf4c0] Frame size: 1440x1080i; bitrate: 145Mbps; pixel format: yuv422p -> 145M -> creates DNxHD 145
wikipedia appears correct for the 4 1080i29.97 (they call it 1080i59.94) entries; they match the official avid dnxhd whitepaper . So the 100M should be the only valid one for 1440x1080i29.97
And that one is the one that does not work.
FFmpeg vs official decoders question
By PU User in forum Video ConversionReplies: 1Last Post: 30th Apr 2022, 10:50 -
Apple dropping codecs including Cineform, DNxHD
By ConsumerDV in forum Latest Video NewsReplies: 1Last Post: 22nd Apr 2022, 04:52 -
Some question about FFMPEG
By kucing in forum Newbie / General discussionsReplies: 2Last Post: 28th Aug 2021, 16:53 -
Size problem with DNxHD
By akkers in forum Video ConversionReplies: 4Last Post: 25th Dec 2019, 05:26 -
cant export to dnxhd in blender
By oduodui in forum EditingReplies: 4Last Post: 14th Jun 2019, 19:52
