Results 1 to 10 of 10
  1. I tried everything with with the encrypted content but I can't seem to bypass it. Is there a way to download and decrypt it?
    Master m3u8 link: d1c7rzyxosh5z.cloudfront.net/spank1-watermarked_hls/master.m3u8
    Stream m3u8 link: d1c7rzyxosh5z.cloudfront.net/spank1-watermarked_hls/media-1/stream.m3u8
    And if it's possible, I can use some guidance on how to get those links!
    Thanks.
  2. Originally Posted by LZAA View Post
    Url?
    https://marintwins.com/content/107/
    is it needed even though direct ts and m3u8 links are reachable?
    i don't know the password.
  3. {"passphrase":"62eeacd8236a9","ciphertext":"+sWRFa paN8jpFmuKErBJwJ6SnuR4Q4Iwi7O1fzLGH9TDMRbh7K7JDjHx umiihe4gMnPBVGpACndmY\/eb3DzgLVpMamj859WnQEPDPtUOR+aAJRNJWzlBDxbxWBGBhBSu ","iv":"fee7a7584717ccb5ca3d88638d9fc52e","salt":" fd9c1cd127cbf0c2e086b295bef1a896"}
    n = "eyJwYXNzcGhyYXNlIjoiNjJlZWFjZDgyMzZhOSIsImNpcGhlcnRleHQiOiIrc1dSRmFwYU44anBGbXVLRXJCSndKNlNudVI0UTRJd2k3TzFmekxHSDlURE1SYmg3SzdKRGpIeHVtaWloZTRnTW5QQlZHcEFDbmRtWVwvZWIzRHpnTFZwTWFtajg1OVduUUVQRFB0VU9SK2FBSlJOSld6bEJEeGJ4V0JHQmhCU3UiLCJpdiI6ImZlZTdhNzU4NDcxN2NjYjVjYTNkODg2MzhkOWZjNTJlIiwic2FsdCI6ImZkOWMxY2QxMjdjYmYwYzJlMDg2YjI5NWJlZjFhODk2In0=", e = JSON.parse(atob(n)), t = e.ciphertext, r = CryptoJS.enc.Hex.parse(e.salt), i = CryptoJS.enc.Hex.parse(e.iv), n = CryptoJS.PBKDF2(e.passphrase, r, {
                    hasher: CryptoJS.algo.SHA512,
                    keySize: 8,
                    iterations: 999
                }), CryptoJS.AES.decrypt(t, n, {
                    iv: i
                }).toString(CryptoJS.enc.Utf8)
    '7b226572726f72223a747275652c226d657373616765223a2249502041646472657373204c6f676765642e2e2e227d'
    getting key but incorrect length
  4. Originally Posted by pkp View Post
                    keySize: 8,
                    iterations: 999
                    iv: i
    yes it has been that way since yesterday but now it should be fixed, i think.
    can you try it again?
  5. 7b226572726f72223a747275652c226d657373616765223a22 49502041646472657373204c6f676765642e2e2e227d
    {"error":true,"message":"IP Address Logged..."}
  6. https://marintwins.com/content/153/
    ^ seems that can be accessed without password, but still getting aes key error.
    so, did they upgrade their software? that means only screen capping works....
  7. hlsdl -b -K 9e75391dc6f69112a4fa69c498641cc2 "https://d1c7rzyxosh5z.cloudfront.net/booblick2-watermarked_hls/master.m3u8"
    > START media_playlist_get_links
    > END media_playlist_get_links
    HLS Stream is AES-128 encrypted.
    {"d_t":"vod"}
    {"t_d":60,"d_d":0, "d_s":0}
    Downloading part 0
    {"t_d":60,"d_d":2,"d_s":797308}
    Downloading part 1
    {"t_d":60,"d_d":4,"d_s":1738436}
    Downloading part 2
    Downloading part 3
    {"t_d":60,"d_d":8,"d_s":3628776} ...
  8. Code:
    https://chrome.google.com/webstore/detail/stream-recorder-download/iogidnfllpdhagebkblkgbfijkbkjdmm
