I have this damaged/corrupted file recorded by Sony PMW-EX1.
Has anyone had the same problem in the past? File is MP4 here's spec from other clean recordings:
Format : MPEG-4
Commercial name : XDCAM EX 35
Format profile : Base Media / Version 2
Codec ID : mp42
Help video Download Link : https://we.tl/t-kpgL4gFSn3
Thank You
Try this. You have to feed it a good file from the same device which it uses as a model to repair the bad file
https://www.videohelp.com/software/MP4-Repair-untrunc-GUI -
Post a small good file to the forum taken with the same device, same settings
Probably the file has a damaged header. You need a good playable video file recorded with the same camera and settings (e.g. resolution, frame rate, etc.) as the corrupted file. Then you can use a video repair tool to extract metadata from the playable file and inject it into the corrupted file. If you're on Windows, you can try a command line tool reocver_mp4. It's free:
https://www.videohelp.com/software/recover-mp4-to-h264
Untrunc mentioned above will also do.
Alternatively, you can use an online app - restore.media.
Also, you can upload a playable sample file and share it here, so we can try fixing the corrupted video with it.
Atomos Ninja2 corrupted file.
By SF01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Mar 2022, 18:51 -
Video File Corrupted .MOV
By VideoHelpPlease in forum MacReplies: 9Last Post: 27th Apr 2019, 11:00 -
Video file seems corrupted
By VideoHelpPlease in forum MacReplies: 0Last Post: 26th Apr 2019, 19:40 -
Sony a6400 corrupted file, HELP! :)
By Ena in forum Newbie / General discussionsReplies: 6Last Post: 10th Apr 2019, 08:02 -
Urgent: Can someone help me recover this broken audio file?
By wizoomer95 in forum AudioReplies: 2Last Post: 8th Feb 2019, 18:59
