Results 1 to 13 of 13
  1. How do I fix this ?
  2. Did you set the path in the profile to the executable?
    Which external encoder do you need? Vdub2 comes bundled with common encoders, and for the most part eliminates the need for the external encoder feature
  3. Originally Posted by poisondeathray View Post
    How do I set the path ?
  4. Originally Posted by poisondeathray View Post
    I just tried Vdub2 & same CLI error
  5. Originally Posted by TheRandomOne View Post
    Setup an encoder profile. Look at the vdub external encoder thread for presets and examples
    ie. Don't use the external encoder.
    The bundled ones are listed in the compression menu , video=>compression . Popular ones like x264,x265 are included , and it supports MP4 ,MKV container export
  6. Originally Posted by poisondeathray View Post
    Okay so in Vdub2 I go to compression & select x264vfw. Followed by file & save video & one of the MP4 options & it says codec not currently supported in container MP4
  7. Originally Posted by TheRandomOne View Post
    Don't use x264vfw
    Use "x264 8bit - h.264/MPEG-4 AVC codec"
  8. Originally Posted by poisondeathray View Post
    Don't use x264vfw
    It looks like MOV works with uncompressed audio but not MP4
  9. Originally Posted by TheRandomOne View Post
    Correct - current open source multiplexers (in other programs as well) do not support uncompressed audio in MP4 container
  10. Originally Posted by poisondeathray View Post
    So basically just export with MOV & mux & convert it all into MP4 / AAC etc ?
    Mar 2008
    Why not just set
    audio/full processing mode
    audio/compression/FFmpeg aac
  12. Originally Posted by davexnet View Post
    Why not just set
    That worked so from here I know whats up so thanks for the help guys
    Mar 2008
    Why not just set
    No problem, got there in the end.
