Hello. I have 2 VHS players, and tried to capture old tapes, and digitize them. On my first VHS player, it was working great, after alliging and cleaning the heads, however during playback the audio went muffled, anything I play on this is now muffled. I tried to clean/adjust the audio heads, but haven't had any luck. I borrowed another VHS player, and the audio is fine, confirming the previous issue is with the player, however, this player has black lines across the video, which my other one doesn't. I've cleaned the head, but it still has the same issue, here is a video of the lines I'm talking about, it's on all vhs tapes, and wasn't on my other player.
https://youtu.be/K8F4FYOSJeY
thanks for your help
Results 1 to 11 of 11
The audio doesn't sound muffled to me in that sample, The black steaks can be caused by "literally" hundreds of things, from loose connections to bad capacitors ...etc. The VCR needs to be seen by a technician to pinpoint the problem and find a fix using the right tools, it is not something that can be fixed over forum posts.
What VCR is it? It looks like an issue with dropout compensation. It might just need an adjustment for the dropout delay line level (often called YNR gain or similar in service manual), but could be some deeper issue too.
Muffled audio can be caused by misadjusted or dirty audio head, though can be other things too, hard to tell. -
If your VHS deck with the muffled sound supports HiFi audio, make sure it's still enabled (ie, playing the HiFi track, not the linear track). You may have accidentally switched the audio at some point.
1. Some VCRs have a button you can push to change from Hi-Fi to linear audio.
2. Do you know if your tape has both a Hi-Fi and linear track? If it only has linear, and it used to sound good, then perhaps you screwed up the alignment of the audio head when you did your cleaning. The audio will definitely get "muffled" if the linear audio head is not aligned.
3. If your VCR doesn't have a button on the VCR to change the audio source, you should be able to find a cheap (under $10) universal remote that has all the commands for your VCR built in. Sometimes TV remotes had some "universal" functions built in, so they could be used to also control the VCR or DVD player, so it is possible that you don't even have to buy another remote.
4. You could also borrow such a remote from a friend or a neighbor. -
This is why I always say never mess with the factory alignment unless you have an alignment tape and the right tools, Sure using a good pre-recorded tape will get you close but never perfect.
An "alignment tape" is overrated.
But I agree with not messing with your primary deck. Only mess with backup decks, and with the understanding you may "break" it (lose alignment, not find it again). And if/when you resell, don't be an a-hole and claim it works perfectly (ie, eBay, where "working" units have oxide shed, misaligned, etc, these days).Want my help? Ask here! (not via PM!)
Overrated in terms of a consumer's "close enough" narrative yes, But professionals who repaired and maintained these machines for the last 3 decades don't use that methodology, Alignment tapes are tapes that are recorded with special factory equipment to a certain degree of precision defined by the manufacturer's admissible tolerances, Prerecorded or commercially recorded tapes can never be trusted for alignment because the gear used to make them do go out of alignment that's why they have maintenance and calibration check schedules.
Audio Muffled on Certain Tapes on JVC but Sounds Fine on Other VCR
By bbmaster123 in forum Capturing and VCRReplies: 31Last Post: 20th Aug 2021, 07:27 -
ConvertToYV12 is smudging out black lines
By killerteengohan in forum RestorationReplies: 1Last Post: 5th May 2021, 12:21 -
How To Fix Muffled GoPro Audio
By blewyn in forum AudioReplies: 2Last Post: 6th Mar 2020, 00:00 -
How to detect "lines" and drop of audio in VHS rip
By gybe in forum Capturing and VCRReplies: 3Last Post: 20th Aug 2019, 05:52 -
Sharpening everything but black lines?
By killerteengohan in forum RestorationReplies: 25Last Post: 30th Oct 2017, 19:32
