Downloaded this zip folder "ctbrec-4.4.5-macos-jre.zip", extracted to "ctbrec-4.4.5-macos-jre", and there are 3 folders and 5 files in it (see attached), how do I run this?
Thanks.
Results 1 to 15 of 15
AnonymousGuest
I don't know anything about mac but i do know about Linux.
So start by reading README.md..
My guess is that this is a java program, if so install java ( i don't know if that is necessary hence the jre folder?) and double click ctbrec-4.4.5-final.jar -
might try reading the Mac OS user guide - https://support.apple.com/guide/mac-help/welcome/mac
AnonymousGuest
can you share what is inside ctbrec.sh?
Open it with a texteditor.
It could be a installer, but it also can be a script to start the application -
AnonymousGuest
The .sh file is a application start script, but it needs java to be installed in /bin/java
So install a java version (witch version i don't know) and give ctbrec.sh execute rights (i don't know how this is done on mac but Linux right click ctbrec.sh and choose properties, tab permission)
Then open a terminal with the directory where you extracted the zip (thus where the files are from the first image of this topic)
and type: ./ctbrec.sh (without root rights, sudo under linux)
This should start the application, but if not i can't help you any further -
Hello Jan
, don't care if you're a boy or girl, I just want to kiss you
I got it working from your instructions!
- Install zulu17.36.13-ca-jre17.0.4-macosx_aarch64.dmg (Optimized for Apple Silicon M1/M2)
- Terminal check Java -version (to check JRE installation)
- Terminal CD and drag ctbrec folder after CD
- Terminal issue command ./ctbrec.sh
- Success
Wishing you a great, happy and sexy day!
Those who bring sunshine into the lives of others cannot keep it from themselves. -
AnonymousGuest
Thanks, i'm glad it worked out, and for a guy that don't know jack shit about mac i did a good job haha
Mac OS is just a glorified+worsened UnixoidThanks, i'm glad it worked out, and for a guy that don't know jack shit about mac i did a good job haha
"Programmers are human-shaped machines that transform alcohol into bugs." -
How to reinstall macOS
By abddd in forum TestReplies: 5Last Post: 7th Jun 2022, 02:59 -
How to add cover to files in folder?
By bradwiggo in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2021, 08:42 -
Program doesn't execute
By XPTO in forum ComputerReplies: 3Last Post: 18th Sep 2018, 13:57 -
Execute youtube-dl package on Windows
By rocks in forum Newbie / General discussionsReplies: 0Last Post: 29th Aug 2018, 08:12 -
Avisynth: How to install plugins? (Already pasted .avsi and .dll in folder)
By strawberryshortcake in forum Newbie / General discussionsReplies: 110Last Post: 14th May 2018, 00:04
