I recently got a Wolverine Movie Maker Pro 8MM converter. Just looking for some guidance to make sure my workflow to convert to MPEG-2 for DVD or compliant MP4 for playback on TV.
The video captured by the device is 20fps. First I'm using FFMPEG to get correct frame rate without re-encoding. Next I'm importing into Vegas 17 and setting resolution to 1440x1080 progressive, PAR to .9091, frame rate to 16 or 18 depending on 8MM or Super 8MM. Then in Video Event FX changing Maintain Aspect Ratio to NO. This gives me a 4x3 square video.
Then to have a DVD or NTSC compliant file encoding to standard 30fps NTSC video matching field order to progressive and PAR to .9091.
Anything else I should be double checking or changing? I just want to make sure if I'm doing it this way it's worthwhile and will give me the best end result possible.
[Attachment 66171 - Click to enlarge]
[Attachment 66172 - Click to enlarge]
Results 1 to 1 of 1
8mm film to digital copying
By Camerart in forum Newbie / General discussionsReplies: 6Last Post: 31st May 2022, 11:55 -
8mm and Super 8 film to frames
By Spektre in forum CapturingReplies: 1Last Post: 17th Aug 2021, 04:08 -
Original file in mp4 format from Reflecta 8mm Super 8mm scanner
By Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 11:56 -
8mm film tearing
By Her0xJune in forum Newbie / General discussionsReplies: 8Last Post: 5th Jun 2020, 23:07 -
Recommendations for Professional 8mm Film Restoration Companies?
By CaptainCatholic587 in forum RestorationReplies: 32Last Post: 31st Dec 2018, 01:14
