I have many mts files that I need to change the container to another more user friendly type. I know that MTS can be converted to MKV but not sure if my mediatype encoding and sound supports that. Here is my mediainfo output for a sample file. I am seeking suggestions for container type to convert to and any recommendations on best practices.
General
Complete name : Y:\Gallery - \Video\2017-08-23 Michelle\Video Right\Michelle.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.89 GiB
Duration : 32 min 26 s
Overall bit rate : 17.2 Mb/s
Maximum Overall bit rate : 18.0 Mb/s
Recorded date : 2017-08-22 23:34:06-06:00
Writing application : JVC
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : 27
Bit rate mode : Variable
Bit rate : 16.2 Mb/s
Maximum bit rate : 17.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.261
Stream size : 3.68 GiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -481 ms
Stream size : 59.4 MiB (1%)
Service kind : Complete Main
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 67 ms
As jagabo stated avc+ac3 is fine in both mkv and mp4 container, but pgs subtitle is compatible with mkv only, not with mp4.
For an easy container change use clever Ffmpeg-GUI, multiplexing section. -
I find mp4 getting more outdated than mkv,kinda like flac replacing mp3 even though most people won't hear the difference between mp3 and flac,just mp4 isn't as easy to use as mkv for adding subs and such.
Thank all of you for your input and recommendations. I will try clever Ffmpeg-GUI, I was not aware of it although in the past I had used ffmped to do some simple cleaning, having a gui to simplify will be of great help.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
What audio container works well with .mp4/.mkv containers? FLAC or AAC?
By Guernsey in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2021, 00:18 -
Rewrap MTS to MP4 w/o re-encoding. Why is MP4 smaller? GUI batch tool?
By Razz in forum Video ConversionReplies: 7Last Post: 13th Mar 2021, 16:24 -
From multiple MTS file to mp4
By mcgyver83 in forum MacReplies: 14Last Post: 21st Aug 2020, 09:58 -
Converting from MP4/MKV to MTS
By smithb in forum Video ConversionReplies: 4Last Post: 17th Oct 2019, 13:21
