Results 31 to 35 of 35
I don't know how to rewrite AVC timestamps with ffmpeg. But I already said
So, just do a remux of your AVC video with MKVToolNix. Set Default duration/FPS to 24000/1001p and check "Fix bitstream timing info".
Of course chances are that after repairing timestamps (if any has been) the offset still isn't constant. In which case I'm afraid the videos are not exactly the same. -
Dear,
I came back with "inspiration and patience", and finaly it worked!
The flow is exactly the one you suggested.
The only strangeness I found is that a/v delay is 2000ms instead of 2752ms expected (66frames of delay between original streams, so 1000ms/(24000/1001)*66=2752ms).
Thanks a lot for your valuable support, really. -
Good you figured it out. I can't explain the difference in a/v delay. Which, tbh, I find rather large. Maybe something else in the AVC mkv was buggered up bigtime.
May I ask how you found the exact 2000ms delay value? And you're sure A/V stay synced throughout the whole video?
4K Video Downloader Scheduled/delayed downloads?
By OldNick in forum Video Streaming DownloadingReplies: 1Last Post: 29th Oct 2022, 01:04 -
Obs studio produces screen capturing files with consequently delayed sound
By Glen in forum Newbie / General discussionsReplies: 4Last Post: 1st Sep 2021, 04:25 -
[help] how to mux video with chapters?
By haclaogia in forum Blu-ray RippingReplies: 2Last Post: 20th Oct 2018, 11:23 -
AviSynth: Use the first frame of the delayed video instead of a black one.
By irn-bru in forum EditingReplies: 2Last Post: 27th Aug 2018, 11:47 -
ismdownloader failed to mux files - how to mux them?
By renesti in forum Video Streaming DownloadingReplies: 2Last Post: 31st Mar 2018, 10:36
