Results 1 to 14 of 14
    Jan 2014
    london england
    Is a player available which will play ProRes 50p? Windows Media Player doesn't seem to play ProRes at all, and while VLC media player does play ProRes 25p it doesn't seem to play ProRes 50p.
    Mar 2008
    Windows 10? 1080p? 4k?
    Jan 2014
    london england
    3840x2160 50p Windows 10
    Mar 2008
    A sample on my PC plays, but it struggling in VLC - this is due to the specs
    of my old PC, CPU too slow.
    Try mpc-hc or mpc-be as an alternative
    A fast (recent) PC will give better results
    Jan 2014
    london england
    mpc-hc works perfectly, though mpc-be doesn't play it at all.. Thank you very much. Also mpc-hc plays ProRes 25p much better than VLC player does.
    Mar 2008
    That's great thanks for the feedback
    Jan 2014
    london england
    How do I make MPC-HC the default player on my PC?
    Mar 2008
    Settings/Apps/Default Apps
    Jan 2014
    london england
    MPC-HC isn't listed there
    Mar 2008
    Did you "install" mpc-hc, or are you using the portable version?
    This is another way:
    Right click the app icon/run as administrator
    view/options/formats - choose the file types you want to activate/ apply
    Jan 2014
    london england
    in view/options/formats i selected everything in the list because I didn't know what not to select, but it still won't play.
    I installed MPC-HC in C/Program Files.
    Mar 2008
    Selecting "all" not recommended, just choose the types you're concerned about.
    One last thing to try - go back to
    windows 10 Settings/Apps/Default Apps
    At the bottom select "choose default apps by file type"
    Check that the video file extensions are what you expect.
    Reboot and retry opening one of the files.
    Jan 2014
    london england
    That worked. Thanks.
