Hi,
Is there a way to check for uhd-bd=1 compliance before I encode something? I'm using Xmedia Recode right now, and I'm using the option for Ultra HD Blu-ray.
This is what the help section says
Enable Ultra HD Blu-ray format support.
If specified with incompatible encoding options, the encoder will attempt to modify/set the right encode specifications. If the encoder is unable to do so, this option will be turned OFF.
I quickly ran an encode using Handbrake with no settings applied other than uhd-bd=1, and it was able to maintain this without going to uhd-bd=0.
So, is there something with these encoding settings below that would cause the encoder to go trigger uhd-bd=0?
Thank you,
Carl.
Encoding settings : cpuid=1111039 / frame-threads=1 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1714 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=3 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=24 / lookahead-slices=0 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / no-signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=1 / limit-refs=0 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / no-deblock / no-sao / no-sao-non-deblock / rd=2 / selective-sao=0 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=0.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=98000 / vbv-bufsize=99000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.00 / aq-mode=3 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=2 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=1 / chromaloc-top=0 / chromaloc-bottom=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.00 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=3 / refine-mv=3 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
I think the trouble lies with the video resolution. 3840x1714 isn't according uhdbd specs. Black borders have to be added first to get compliant 3840x2160 resolution.
I don't know of any GUI tool that can help adding the borders, but AviSynth can do this. I always do this in software like MeGUI. It has a build in script creator. It does require some basic understanding of how to edit such a script. Which isn't difficult.
The filter in AviSynth you need is called "AddBorders". For your video, you can add the following text to the AviSynth script:
AddBorders(0, 222, 0, 224)
This will add 222 pixels black border on top and 224 pixels at bottom. Of course you can change these two nummers, but be sure they add up to 446 in this case (your vertical resolution of 1714 needs 2160 - 1714 = 446 pixels totally added). As you're probably dealing with 420 chroma-subsampled video, avoid using odd numbers.
http://avisynth.nl/index.php/AddBorders
UHD to Blu-ray Bitrate?
By kpic in forum Authoring (Blu-ray)Replies: 9Last Post: 5th May 2021, 10:59 -
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Sep 2020, 04:39 -
UHD Blu Ray Spec
By premiumcapture in forum Authoring (Blu-ray)Replies: 3Last Post: 13th May 2020, 21:04 -
Rip Blu-ray and UHD Movie
By Roosvelt in forum Blu-ray RippingReplies: 39Last Post: 18th Nov 2019, 15:12 -
Ripbot264 Convert UHD Blu-ray 4k to Blu-ray 1080p
By microhunt in forum DVD RippingReplies: 0Last Post: 23rd Dec 2018, 11:12
