Just aquired a SONY TRV608 Hi8, Seems to work flawlessy.
https://www.sony.com/electronics/support/res/manuals/3072/30723141M.pdf
No Firewire is Available.
No RCA Capabilty on the Camera.
Its Output Ports Are:
- USB
- S-Video
- AV Out
1. I have pretty consistently read that USB is too low a transfer rate to be effective. The Dilema is I keep seeing Capture Devices with USB for their, "Source" Cable from the Video Camera. Can I please get some clarification if the USB Option is in fact a poor one?
2. I have the S-Video Port to work with and no RCA Ports on the Webcam. I don't see many Capture Devices with S-Video as the Webcam Source. if this is the preferred option, ny recomendation for Device Choice(s) Money is a consideration so max of $100 will be a stretch.
- Also can I go S-Video to S-Video on a capture Device such as DVD Recorder or PC?
3. AV Out - How is this as an Option? Again, I see very few External Devices that work from this?
4. If it would be best to use a card in My PC as a Direct Connection, I have the ability to install one. I am running Win 10 and have a PCI X16 Slot to use. I have a DVI Slot, and several USB Slots already in-place. Also HDMI. I believe my Processor is 2.8 GHZ, 8 MB RAM and plenty of Hard Drive Space Remaining of 500 MB. I do have a DVD Writer Installed as well.
I, "may" consider doing conversions for others. I just retired and this looks like a, "doable" side gig to me once I gain adequate knowledge. I am considering a VHS to DVD Recorder purchase at a Thrift Shop for just ten bucks. It is a Panasonic DMR-30. I have a few family VHS Tapes I'd love to convert over so can use them to check functionality. (I'll practice on some old Movie Tapes before chancing Mangling my family ones!)
I'm an ignorant old sponge thirsty for advice and opinions at this time so any and all assistance will be greatly appreciated!!!
Last edited by dougf4; 27th Jul 2022 at 19:29. Reason: Hi8 Tape Preservation to Digital Copies
s-video (plus audio from the AV port) if your capture device supports it. Then composite (AV port). Forget USB.
(SORRY THAT I SOMEHOW POSTED THIS PREVIOULY PRETTY MUCH EMPTY)
Its Otput Ports Are:
- USB
- S-Video
- AV Out
4. If it would be best to use a card in My PC as a Direct Connection, I have the ability to install one. I am running Win 10 and have a PCI X16 Slot to use. I have a DVI Slot, and several USB Slots already in-place. I believe my Processor is 2.8 GHZ, 8 MB RAM and plenty of Hard Drive Space Remaining of 500 MB. I do have a DVD Writer Installed as well.
When converting Hi8 and Mini DV tapes I wonder which one is the best choice
By jsj2251 in forum Capturing and VCRReplies: 7Last Post: 13th Apr 2022, 11:21 -
Hi8 player for conversion
By johnzoo in forum Video ConversionReplies: 2Last Post: 17th Jun 2020, 15:24 -
Capturing BNC Video Output Port from X-Ray Machine
By diontan in forum Capturing and VCRReplies: 9Last Post: 19th Nov 2019, 01:14 -
Noob questions on conversion
By ultane in forum MacReplies: 3Last Post: 14th Sep 2019, 22:37 -
Noob here, Looking for suggestions on how to capture Hi8 tapes for editing
By lonski in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2019, 15:43
