I just bought this Clear chick v2.0 capturing device and straight out of the box its been having problems. I captured something and the video is jittery at first then stops but then the jittering happens again. The camera im capturing it from is a Panasonic palmcorder pv-l352dI have no clue on what to do. Attached is a sample video of what is happening
You need a time base corrector. An old Panasonic ES10 or ES15 (about US$100) in passthrough mode will probably fix most of it. You're capture device, though it's easy to use, is going to give less than stellar results in any case.
Clear Click is an infamous POS garbage item, like the Easycaps (aka Easycraps).
It will always look terrible.Want my help? Ask here! (not via PM!)
Also the camcorder is very low end, Use a high end full size VHS VCR or get a device in between that stabilizes the timing like the a DVD recorder, and yes that capture device is a chinese piece of cr@p, You should be looking into getting a better capture device.
Capturing miniDV tapes. Very new to this. Please Help.
By JontheScott in forum Capturing and VCRReplies: 38Last Post: 12th Jun 2021, 06:20 -
Problem capturing audio with some Hi-Fi vhs tapes
By Altruo in forum AudioReplies: 5Last Post: 23rd Apr 2021, 20:05 -
Capturing Hi8 tapes
By TheDrifter363 in forum Capturing and VCRReplies: 46Last Post: 2nd Feb 2020, 13:18 -
Capturing Tapes to ProRes vs DV
By Christina in forum Capturing and VCRReplies: 317Last Post: 28th Apr 2019, 23:04 -
Capturing VHS tapes
By mtamimi in forum Capturing and VCRReplies: 7Last Post: 3rd Mar 2018, 01:09
