Hi, can anyone recommend a known 32bit linux distro that will work to access the internet? I have a Dell D620 laptop that runs on the 32 bit system. I have Linux mint 13 installed on the D620 HDD, works great but I only use it offline and for secure storage. I require a linux operating system for this machine for secure... ish browsing only. Many thanks
Results 1 to 10 of 10
Health IS the first Wealth------So do not strain your eyes!
Hi davenet , thanks for the link. A little concerned about this download. Reading some of the reviews. Check out the user reviews https://mxlinux.org/wiki/system/iso-download-mirrors/ I have never downloaded a Linux ISO before, always used USA seller or ebay. I will give this one a bit more thought before downloading it, but very welcome for the pointing in the right direction. Many thanks.
Health IS the first Wealth------So do not strain your eyes! -
davenet, got the ISO from Sourceforge, very easy, not checked the md5 "checksums", will let you know how I get on with this distro. Cheers, thanks for the link.
Better safe than sorry, however - those download links on the page I mentioned already point to Sourceforge.
You can look at this page for detailed info about all popular releases
https://distrowatch.com/
MX LInux #1 in popularity right now -
That's quite true. It's just a matter of time.
A bigger issue may be how much RAM that box has. Nowadays browsers and many web pages are enormous memory hogs.
I use MX 21 but for an old 32 bit machine Antix would probably be better. MX and Antix are related distros and MX is really meant more for newer machines. Most Linux distros (and desktop environments) are nowadays. Antix is more suitable for old hardware with not that much RAM.
BTW MX may be #1 on distrowatch but that's just based on the # of hits on their site and is utterly meaningless. MX 21 KDE is fabulous but distrowatch had nothing to do with me wanting to try it. -
Debian still has 32bit support
if all else fails read the manual -
Anonymous19484Guest
You could maybe use one of these:
https://puppylinux-woof-ce.github.io/
or
http://www.tinycorelinux.net/
those distros are specific for low hardware
[LINUX] can ffmpeg (or any othe linux command) genere an ANIMATED waveform
By Jintor_Universe in forum ProgrammingReplies: 5Last Post: 28th Oct 2021, 20:29 -
Transforming 32bit VirtualDub filter into 64bit?
By Troc in forum ProgrammingReplies: 10Last Post: 8th Nov 2020, 18:52 -
if mpv-32bit doesnt work with XP then what is this 32bit version for?
By sommers in forum Newbie / General discussionsReplies: 4Last Post: 14th May 2020, 11:52 -
DVDFab for Linux
By nypaulie in forum LinuxReplies: 3Last Post: 11th Jan 2020, 18:47 -
linux whine
By aedipuss in forum LinuxReplies: 6Last Post: 7th Nov 2019, 13:12
