Hello Guys how to remove this artifact?
I believe it's called comets right?
Thanks in advance!
15 seconds Sample
sample.mkv
Results 1 to 14 of 14
Unfortunately, you video has been deinterlaced so DePulse will probably not work well.
this will remove some, without artifacts
SetMemoryMax(900)
SetMTMode(3,4)
LWLibavVideoSource("sample.mkv")
SetMTMode(3,4)
noisy = last
nonoise = SpotLess(last)
sharpen=0.0,interlaced=false,dehalo=0.0)
diff = 1 # Difference between denoised and noisy clips
m = mt_lutxy(noisy,nonoise,"y x - "+string(diff)+" - 255 *")
mt_merge(noisy,nonoise,m)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Like this, sorryCode:
noisy = last nonoise = SpotLess(last) diff = 1 # Difference between denoised and noisy clips m = mt_lutxy(noisy,nonoise,"y x - "+string(diff)+" - 255 *") mt_merge(noisy,nonoise,m)
I tried like this
and it's giving scripterror: There is no function named 'SetMTMode'Code:SetMemoryMax(900) SetMTMode(3,4) LWLibavVideoSource("sample.mkv") SetMTMode(3,4) noisy = last nonoise = SpotLess(last) diff = 1 # Difference between denoised and noisy clips m = mt_lutxy(noisy,nonoise,"y x - "+string(diff)+" - 255 *") mt_merge(noisy,nonoise,m) -
SetMemoryMax(900) SetFilterMTMode(3,4) LWLibavVideoSource("sample.mkv") SetFilterMTMode(3,4) noisy = last nonoise = SpotLess(last) diff = 1 # Difference between denoised and noisy clips m = mt_lutxy(noisy,nonoise,"y x - "+string(diff)+" - 255 *") mt_merge(noisy,nonoise,m) -
Remove all the SetMemoryMax() and SetMTMode() and SetFilterMTMode() lines.
And always indicate the error message you got. -
This is good advice for beginners. I played around with it last year, but never had much luck.
There's an mtmodes.avs that has the modes for all the popular filters, even still,
seems like a bit of a kludge.
Probably better to learn Vapoursynth
help fixing 29.97fps video
By maudit in forum Newbie / General discussionsReplies: 19Last Post: 22nd Mar 2022, 01:18 -
which filters to remove dropout or comets, and where get them
By spiritgumm in forum RestorationReplies: 13Last Post: 24th Feb 2021, 21:02 -
Fixing out of sync Audio
By Wingston in forum AudioReplies: 12Last Post: 24th Dec 2020, 23:28 -
Fixing Comets
By Okiba in forum RestorationReplies: 20Last Post: 19th Nov 2020, 00:56 -
Fixing videos
By ydiana in forum RestorationReplies: 11Last Post: 9th Aug 2019, 10:19
