Would anyone be willing to sell me an 8mm tape with some analogue (video8 or Hi8, LP or SP) NTSC format footage recorded on it? I just tried playing a Digital8 NTSC tape on a Sony DCR-TRV320E PAL and captured the footage successfully with Ulead software. Previous attempts with other softwares had failed, as the picture was completely broken up and unusable. I would really like to try capturing an analogue 8mm recording, to see if it works. I'm in the U.K.
Results 1 to 12 of 12
I can not help with the tape but I must ask why NTSC ?
Yes, the camcorder does offer NTSC 3.58 and NTSC 4.43 playback on PAL but I see little point (just my opinion) why you need to test that unless you had other NTSC tapes apart from the one just transfered.
One other thing. What cable A/V, s-video or i-link are you using ? Other than the last one you are converting that digital recording to analogue and that initself might be cause of your previous issues. -
Someone is Saudi Arabia wants to use it to transfer his analogue 8mm recordings to computer, via firewire, and he has a mixture of PAL and NTSC recordings. I didn't want to waste the postage costs to send it all that way, if it wasn't going to work. He doesn't want to risk sending a tape to me, in the U.K., as they have precious family footage on them.
Ok.
I may be wrong here but AFAIK NTSC playback to PAL is NOT available for digital >> firewire/i-link. One would require a pure NTSC camcorder.
You could still do an analogue transfer via A/V or s-video as long as the capture device supported PAL60 -
^^ The manual quotes 2 options >> NTSC over PAL playback (surely that is standard 3.58) aka PAL60 and NTSC 4.43.
This always gets me! So is it NTSC 3.58 60fps with PAL chroma?
^^ Almost correct. 29.97 fps (59.94 fields) 720*480 and, yes, PAL chroma.
The one that actually throws me is NTSC 4.43. And only certain capture software such as vdub supports that. Even PAL60 has to be supported at driver level.
Back in the day, before I discovered this place, I was also, like the OP, using Ulead s/w to grab a DV stream. Of course I was only using PAL whereas we here have a mix -
Yeah I know that part, I'm just too lazy to write down the decimal numbers and I tend to forget which decimal number goes to which frame rate .97 vs .94 and 29 vs 59, And also angry to why we're still using this idiotic decimal frame rates when there is really no need for them anymore, They served a purpose during the analog transmission era of TV but we should let go of now, We Americans don't like to let go off of old stuff for example cars.
I just tried playing back a Hi8 NTSC short play recording on a DCR-TRV320E PAL Digital8 camcorder and it played back fine. It would not playback a video8 short play NTSC recording without a lot of distortion of picture and sound. No software which I have would capture from the firewire connection, although they will capture from a PAL analogue recording.
What software did you try? The recommended programs for DV FireWire transfer are Scenalyzer and WinDV.Originally Posted by Nevillestyke
ULEA, Sony's own (which crashed, citing incompatible formats mixed together) and Pinnacle (which has always had trouble with NTSC played back on a PAL camcorder, even when its a DV recording and DV camcorder).
Sony Digital8 camcorders can play both NTSC and PAL DV recordings.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 31st Aug 2025, 08:16 -
Help with old shaky 8mm/super 8mm videos
By zfishman in forum RestorationReplies: 2Last Post: 11th Apr 2021, 03:33 -
Original file in mp4 format from Reflecta 8mm Super 8mm scanner
By Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 11:56 -
Do Sony Digital 8 Camcorders Play Back 8mm as Well as 8mm Equipment?
By audioresearch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Jun 2020, 01:12 -
TRV120 D8 cam won't play most old 8mm tapes, any recommended 8mm camcorders
By analog2digital in forum Capturing and VCRReplies: 1Last Post: 22nd Feb 2020, 11:44
