Hi guys I have an i3 7100 processor with igpu Intel 630 and I use this PC for encode, now am using Topaz video for upscaling and the time remain says 3 days and 16hs, I so need to know what about if I let the computer do the job? the processor will crash or someting? damage?
I so need to know if I can let the igpu encode? and what about if the encode time takes more time itīs ok?
Thank You in advance!!
If you can keep the hardware cool, if the power doesn't go out, if the operating system is stable. You should be ok.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Video editor without re-encoding ?
By Nagasaki in forum Newbie / General discussionsReplies: 18Last Post: 11th Aug 2026, 14:35 -
Video Encoding
By biferi in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2022, 07:15 -
How to convert .m2ts video to .mkv video without re-encoding by ffmpeg ?
By aaajan in forum Video ConversionReplies: 13Last Post: 27th Aug 2021, 08:30 -
Video Joining without Re-encoding
By THRobinson in forum EditingReplies: 7Last Post: 11th Aug 2021, 16:45 -
Video not encoding at specified bitrate?
By killerteengohan in forum RestorationReplies: 6Last Post: 5th Jul 2018, 10:14
