Results 1 to 9 of 9
  1. hi everyone, does anyone know which program can do a hardsub with no or minimal loss of quality? I used to use format factory and HandBrake, but the output format is too bad for 1080 and 720 video
  2. Handbrake's quality is adjustable. From terrible (very small file size) to lossless (very large file size). You just need to use better settings.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Handbrake will do the job,you just need to know what are the best settings to do the job,do a few test encodes at 16.18,20 constant quality and see which you like versus size and quality.
  4. I've tried, but it takes too long
  5. Handbrake is the same speed as all the other encoders when you use the same settings.
  6. not sure, because in FF a 20 minute file takes about 5-7 minutes and in HB over half an hour. the settings are the same
  7. Originally Posted by jessezveneberg View Post
    No, they're not. Format Factory uses the same open source decoders and encoders as Handbrake (ffmpeg, avcode-52, and avformat-52). They just don't tell you so.
  8. I'm a Super Moderator johns0's Avatar
    canada
    What type of system are you using?
  9. windows 10 x64
