I want to upgrade RAM Memory from 8 GB to 16 GB ( Adding a new component 8 GB ).
It's a DDR4, 2133 MHz but I don't know the mark of the installed RAM.
Is it absolutelly necessary that the mark of the new memory is the same that the already installed?
Thanks for your advice.
Results 1 to 12 of 12
Download CPU-Z (Freeware)
Start it and look up Memory and then SPD for detailed information. There you can see the manufacturer of the DIMMs and also the manufacturer of the used RAM modules on the DIMMs. You get also the partnumber of the DIMMs
Are you sure you are running 2133 MHz? This is normally only the base frequency and after enabling XMP it has the full 3200, 3600, or more MHz -
Thank you flashandpan007.
May I conclude I cannot use two memories of different manufacturers? Is that a grave option? -
You can, but I don't recommend it.
I could look for an 16 GB Kit for you which will do fine and doesn't cost too much.
A good price/performance kit for example, but remember to enable XMP in the BIOS in your mobo:
https://geizhals.de/g-skill-aegis-dimm-kit-16gb-f4-3200c16d-16gis-a2151626.html?hloc=de -
Depending on the use and my budget at the time, over the years I have built many systems that used memory from different manufactures, different speeds, different timings, different sizes.
I remember on one older system, I needed to get it to 4gb ram (this was years ago), so I out in a 2gb stick and 2x1gb sticks, each with different speeds and timings.
It did what I needed it to do at the time. -
Well I have also mixed ram from different manuf. and diff. speeds.
Ultimately it depends on the mb. and you need to read the manual for that - or the online - for specific memory compatabilty.
What I did find for my own system is that faster memory slowed down to be compatable to the slower so the slower had to be in the initial slot(s) else the whole system borked. -
I also have built many boxes for years, and can say that while it is often that you can get things to work, it is never as good performance as getting a matched set.
And, even when it works, with unmatched stick combos there can be minute timing mismatches that occasionally result in weirdness - hangs/freezes, corruption. It seems to all depend on whether the differences between the sticks' specs are near or beyond a system timing threshold. If this is the case, that would support the assertion that it it can work for some combinations but not others.
If you have the budget, I wholeheartedly recommend getting a matched set.
Scott -
Thanks to all suggestions.
I'm going to buy a 2nd. 8 GB module from Crucial
so the manufacturer is the same. -
I would buy the same exact 8gb ram,buying a 8gb module from the same manufacturer is like buying from any other manufacturer unless its the exact match.
I agree. You want exact same speed, memory structure (DDR...), as well as same mfr.
Scott -
Latency and parity checking should certainly also match.
DDR4 Ram Problem
By adamf154 in forum ComputerReplies: 13Last Post: 26th Oct 2020, 17:30 -
Upgrading RAM
By kyrcy in forum ComputerReplies: 6Last Post: 9th Jan 2019, 21:49 -
The state of memory (RAM, that is)
By Seeker47 in forum ComputerReplies: 9Last Post: 6th Jan 2019, 12:09 -
Passing analog video without power
By vivitern in forum Newbie / General discussionsReplies: 4Last Post: 15th Nov 2017, 10:21
