I have done a lot of reading here, but still not sure what most would consider best practice doing this. I capture lossless using a Newtek VT5 system and clean up the file and adjust audio to -12db. I then render that out to uncompressed AVI to encode to MP4. I like to deinterlace and double the frame rate. To me that makes the video play much smoother if there is a lot of movement. I had done several tapes and rendered to 720x480. I noticed in playing back in the VLC media player that if you switch between default aspect ratio and 4:3 that the screen is slighted expanded horizontally in the default mode. It seems that resizing to 960x720 may be better as someone mentioned on here. That gives true 4:3 ratio and plays back without any issues. Also, at this size if you upload to YouTube the double frame rate doesn't change, at 480 it will change back to 29.97. To me it seems that would be a plus especially with any fast movement in the video. Just wondering about others opinions. Unfortunately, to make the MP4 this way I'm going to have to re-encode about 40 video's. Luckily, I still have most of the uncompressed files backed up.
More and more people are wanting MP4 instead of DVD's. I want to make sure I do it right. I like DVD better since you can have a menu, but it seems that technology is going to fade away also.
Thanks for any input,
Marty
Results 1 to 14 of 14
960x720 makes no sense, Besides resizing 480 to 720 horizontally will hurt the video. If youtube is the aim, deinterlace and crop to 704x480 then resize to 1440x1080 and encode to h.264 from there.
As I understand it youtube will not (re)encode at 60 fps unless you upload 1080p or more. That's why your 720p videos are encoded at 30 fps.
Thanks for the reply’s. Dellsam34, if never going to YouTube, would you still resize to 1440x1080 or just encode at 720x480 or more preferably crop to 704x480 deinterlaced and double frame rate? I would think resizing is probably doing more harm than good if never going to YouTube. Encoding for DVD is much more straight forward than for MP4 in my opinion.
Thanks again,
Marty -
YouTube does HFR on every resolution higher than 480p (720p,1080p...). It does however reencode every video you upload onto that platform
Resizing to a bigger resolution such as 1080 does less harm than a far less resolution, however it will still have the SD video quality. What I would suggest is keep the master files and make a playback version by de-interlacing, cropping, resizing to 1440x1080 and encoding to h.264, This will be compatible with most TVs and devices on the market today.
This will lower the video quality. If you absolutely must, it is best to 1280x720, but only with filters that improve quality (yadif deinterlace, denoise, sharpen etc.). Otherwise it doesn't make sense.
720 vs 1080 after encoding to h.264 have almost same size, So why resize to 720 and have worse quality vs resizing to 1080. In addition to that the TV's have to do another hardware resize on the fly during playback to 1080 or double that if the TV is 4K. As I always say 720 doesn't make any sense anymore since no native 720 panels are being made. It was a cheap trick back in the day to do progressive for sporting events since camcorders processors back then were not capable of doing 1080p yet, It should never have stuck around when 1080p became available shortly after.
If they are of the same size, 720p will be of better quality then because it is less compressed. You can't fool the compressor, 1080p is 2x more data.
Hmmmmm, Some people still have the Nipkow TV 32x32 pixels, does that mean it is a standard that I have to worry about in 2022? We are talking about the majority of TV sets available which is HD/4K. The subject is future proofing not pleasing everyone on the planet.
you can't future proof sd video.
tell the viewer to change aspect ratio for best viewing
either upres to 720p or use an html5 player on your own server.
streaming is in, with downloads a far distant 2nd. No one (millions) care about menus since the complex ones require an expert in photoshop and graphic design. -
Off course we can, We've already done it, Watching 40's, 50's, 60's 70's videos on today's TV's. Footages that moved across several video formats throughout the years and they can go for as long as we want them to go, If that's not future proofing I don't know what you call it.
ffmpeg losing subtitle track converting MP4 to MP4
By the_steve_randolph in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2021, 17:42 -
vhs to mp4 ...
By Tom81 in forum Video ConversionReplies: 13Last Post: 17th Mar 2021, 13:27 -
Hybrid Settings for converting Mini DV and VHS AVIs to MP4
By jharmon203 in forum Video ConversionReplies: 2Last Post: 18th Dec 2019, 09:32 -
Ripping VHS tapes to MP4
By zroboy in forum Video ConversionReplies: 6Last Post: 10th Dec 2019, 00:42 -
.vhs to MP4 or any current
By scotsue in forum Video ConversionReplies: 1Last Post: 1st May 2019, 09:39
