I need a program not too big, to convert music videos into MPG, it's to play on an old car device. Any free programs?
If you are referring to Mpeg1, the original TMPGEnc encoder can do that, for free (if you try to do mpeg2, you would need to pay for it).
The question then becomes Can that app accept your input filetypes?
Of course you could also do this for free and easily in ffmpeg, with or without using a GUI.
Scott -
I did this with ffmpeg from a command line .
Then your software.
Both worked.
It would be a nice addition to have a log file.
As an option.
The OP didn't say if theirold car device
I didn't find any converter that would do MP1 audio .
It's likely that nothing would play that. -
I found this one,
[Attachment 66047 - Click to enlarge]
It worked perfectly for what I wanted to do with the MPG II
Which program should I use for HD encodes?
By Alphantom in forum Video ConversionReplies: 7Last Post: 3rd May 2022, 04:16 -
Need Help Deciding What Program To Use
By Loplop in forum Authoring (Blu-ray)Replies: 2Last Post: 27th Oct 2020, 18:15 -
Program not works
By XPTO in forum ComputerReplies: 3Last Post: 29th Jun 2019, 08:33 -
Converting with old PC, which program better?
By GreyAlex in forum Newbie / General discussionsReplies: 7Last Post: 13th Mar 2019, 15:23 -
Program Type help
By biferi in forum EditingReplies: 1Last Post: 18th Nov 2018, 16:38
