I Live in the USA and got the JimTab M18 Pro. Projector.
It was around $200 and it is Native 1080 Resolution.
I have had a lot of Problems with it.
If I have a lot of Video Files on my SD Card it will not Read them at all.
I have my Roku Plus Stick Pluged into it and it is only 15 Feet away from the WiFi and the Images Locks Up every 15 Seconds then plays ok and does this over and over.
I did get another one and the same things go on.
I do not want to get a DLP Projector because I do not want to Replace the Bulb.
I do not want to Break the Bank because I am not using this for work.
I would like it to Play the Roku Plus Stick and the most Common Audio and Video Files.
I would like it to be Native 1080 Resolution.
Does anybody use one and that they like or can give me help?
How much are you putting on your sd card?There maybe a limit to how much you can put on and as to wi-fi can you connect directly,might be your router thats at fault for that.i read all the reviews for your model and nobody had the issues you are mentioning.
Sounds like a file size and network bandwidth issue, if you're trying to stream large files over your LAN your files may be too large for the wireless connection to handle. Another possible issue, projector should be on a 5 ghz wife connection not a 2.4 for max bandwidth.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Help on a Optoma HD29HLV projector
By EMily projector newbie in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2022, 06:42 -
Projector help
By biferi in forum Newbie / General discussionsReplies: 22Last Post: 25th Apr 2022, 02:41 -
Looking for a portable projector
By Rjones in forum Portable VideoReplies: 2Last Post: 2nd Apr 2021, 08:18 -
super 8 projector help
By Benderz in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2020, 22:46 -
How to connect an iPhone to a projector?
By pixelPIC in forum User guidesReplies: 1Last Post: 11th Sep 2017, 20:09
