Results 1 to 9 of 9
  1. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Hello, I want to download this two teaser videos in french audio version with ffmpeg : https://www.netflix.com/re/title/81193032 (Johnny Test)
    Weirdly, when I download it with an addon, I only get the english audio.
    Could you help and give me the links/command's line to use with ffmpeg? Thx for reading
  2. Banned
    Apr 2022
    Hong Kong
    There are some downloaders on the Internet, why not just use them
  3. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    I tried already, all I got are the english audio versions.
    And I admit that I like ffmpeg, it works well with my dinosaur device
  4. I tested with yt-dlp & 4k Video Downloader
    I got one video from the link you posted.
    It is .
    8.73 MiB 1 min 13 s
    It is in English & no option for French.
    I checked the options on the site & I could select French but I found no way to copy the URL with French.
  5. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Aw ok it's not possible then.
    Thanks a lot for trying @cholla
  6. You could try this:
    https://www.videohelp.com/software/Open-Broadcaster-Software
    On the Netflix web page.
    Play the video.
    In the lower right corner is a language selection.
    Select Francois & use the screen recorder.
  7. I hope these are OK to post.
    They are just the teasers.
    They are in French(as far as I could tell as I don't speak French).
    If not will a mod please remove them.
  8. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    @Cholla @LZAA Thank you so much! You rocks!
