Hi, I need some help please,
I'm using mkvtoolnix and I'm dealing with adding a dub PCM audio from another source,
and I get the following error message, can I fix it?
The file PCM was not recognized as a supported format (exit code 2).
checking both PCM files with mediainfo,
the first already encapsulated is this:
while the PCM that does not load is this, with missing info:Code:_ - 3 - PCM, English, 2.0 channels, 24 bits, 48kHz.pcm Format : MPEG Audio File size : 1.44 GiB Overall bit rate mode : Variable FileExtension_Invalid : m1a mpa mpa1 mp1 m2a mpa2 mp2 mp3 Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Format settings : Intensity Stereo + MS Stereo / CCITT Bit rate mode : Variable Channel(s) : 1 channel Sampling rate : 48.0 kHz Compression mode : Lossy Stream size : 1.44 GiB (100%)
while using useac3to to create a FLAC from the PCM, I had no problems at all.Code:- 3 - PCM, Italian, 2.0 channels, 16 bits, 48kHz.pcm File size : 980 MiB
Mkvtoolnix
By fits79 in forum Video ConversionReplies: 11Last Post: 28th Jul 2022, 11:24 -
Potplayer - exit fullscreen after playback
By UsefulDrivel in forum Software PlayingReplies: 1Last Post: 14th Apr 2022, 18:15 -
MKVToolnix exit codes, how use them
By UserName351 in forum EditingReplies: 0Last Post: 18th Dec 2021, 18:30 -
"Real" untouched Remux of an UHD BluRay: eac3to vs. mkvtoolnix vs. MakeMKV
By Gregostus in forum Blu-ray RippingReplies: 2Last Post: 25th Nov 2020, 16:36 -
Help for Batch Code MkvToolNix & Extract
By alloar in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2018, 15:42
