I am trying to delete video files from the internal memory. To achieve this I have connected the USB facility on the camcorder to a pc and using the delete facility of Windows file explorer I am attempting to delete the video files. The problem is nothing is happening. Any suggestions?
page 41 in Manual
format card
be erased and cannot be restored. Back up important data on a PC, DVD disc etc. (l 108,
121)
1 Touch [FORMAT MEDIA].
2
Touch [SD CARD] or [Built-inMemory].
Touch [SD CARD] or [HDD].
≥ When formatting is complete, touch [EXIT] to exit the message screen.
≥ Perform a physical formatting of the SD card when the SD card is to be disposed/
transferred. (l 150)
≥ Perform a physical formatting of the bu -
Many thanks for your reply. The problem with a format is that it erases all the files. I only want to delete several files in the internal memory not all of them, Thanks again,
The only answer is to save the files you want to keep on another storage device first then format
Hello. I am using the HDC-TM900 for video streaming and I cannot get the “record” & “pause” words to stop coming up on the screen. Can someone please help me with turning these off?
if you have tried everything and still no success what I do is -check to see if there is any updates for that model- reboot back to initial settings - disconnect the battery - used a different memory card.
Ok it does mean having to set the camcorder back up which is a pain but usually clears any errors. -
make video everyday
Videorekorder Panasonic nv hv 61
By Jaroslav123456 in forum Capturing and VCRReplies: 3Last Post: 30th Jan 2022, 15:04 -
Panasonic writer
By unclebob in forum ComputerReplies: 5Last Post: 19th Dec 2018, 13:34 -
Panasonic DMR es-18
By Joe S in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2017, 16:34 -
Software to trim AVCHD MP4 files from a Panasonic Panasonic DMC-TZ70
By Vladimir81 in forum EditingReplies: 2Last Post: 29th Aug 2017, 05:15 -
Please help - panasonic gx8
By Hollie57 in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2017, 04:47
