I am seeking help with reviewing files recovered from a ZOSI DVR HDD.
Most of the files are swf extension, I have done some looking and ended up here but I don't know enough what to do. I think I need to convert these files in some way in order to review any of the footage.
I have opened the files into MediaInfo and received this type of feedback:
Appreciate any feedbackCode:General Complete name : D:\7617 dump\recup_dir.1\f109759640.swf Format : HEVC Format/Info : High Efficiency Video Coding File size : 3.00 GiB FileExtension_Invalid : hevc h265 265 Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4.1@Main Width : 960 pixels Height : 1 080 pixels Display aspect ratio : 0.889 Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Full Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Results 1 to 10 of 10
VLC played the sample I found but Mediainfo showed it as a Shockwav with .mp3 audio.
It is not one I can upload on this forum.
The one you posted the MediaInfo on is too large for this forum.
If you have one 500MB or smaller & put in in a .zip file you can upload it here.
Also have you tried to play them with your browser ?Last edited by cholla; 21st Jul 2022 at 19:19.
Try Swivel
https://www.newgrounds.com/wiki/creator-resources/flash-resources/swivel
You could also use a flash decompiler and export the movies and sounds section
https://github.com/jindrapetrik/jpexs-decompiler/releasesLast edited by ProWo; 22nd Jul 2022 at 02:50.
Chrome just put the file in downloads rather than attempt to play it.
AVIdemuxer "could not find a demuxer for the file" - could not open the file (tried several of the files)
Swivel gave Error 2038 File I/O Error
JPEXS cannot load java io exception incorrect stream properties
These files were recovered from a DVR camera recorder's disk after the footage was deleted. They are not video files that have been exported. I used Photorec to retrieve the data, but I just don't know what should happen next for the files onhand to be reviewable.
Here is a small file from the folder. -
Drag the file into mkvtoolnix GUI and remultiplex to MKV.
Produces a working file
Recovering VHS/Beta PCM Video DATA
By dellsam34 in forum Capturing and VCRReplies: 61Last Post: 18th Jan 2025, 15:28 -
Video Camera Footage has staggering in it, not sure if it is the video
By tracylee3124 in forum Capturing and VCRReplies: 10Last Post: 10th Nov 2021, 09:46 -
Free Video Footage for Your Projects
By Eric Matyas in forum EditingReplies: 8Last Post: 23rd Feb 2021, 09:22 -
Getting Footage off DirecTV DVR--Best Method?
By hypnicjerk in forum DVD & Blu-ray RecordersReplies: 20Last Post: 13th Nov 2019, 20:07 -
What to do with 36 hours of family video footage?
By Casho in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2018, 12:02
