Hi all, new here.
I'm working on a program that can extract i-frames from potentially fragmented or corrupt video. In my test data set I've come across a video that I don't understand, which I've attached.
I thought that for MP4/AVCC, the NALU size is four bytes which prefix the start code (0x65 for an IDR frame). I have used ffprobe to give me a list of the I frames with their sizes, however when I scan through this particular video in HXD, I can't find any of these sizes referenced before each NALU, and each NALU is in fact much smaller. My program tries to extract these 0x65 prefixed NALUs and convert them to JPEGs, but it spits about a bunch of partial frames. I don't get this with any other video in my dataset which is a couple thousand videos, those spit out full frames.
If I had to make a guess I'd say that the i-frames are being split across multiple NALUs. I'd like to try and understand a bit more about this mechanism. Is there a way to tell how many NALUs go into each i-frame outside the metadata. Does the SPS/PPS specify this for example? Is it naive to assume that full i-frames exist within a single NALU?
Cheers
0.000000,6525,K_
0.200000,6517,K_
0.400000,8445,K_
0.600000,9599,K_
0.800000,9686,K_
1.000000,9423,K_
1.200000,10191,K_
1.400000,9962,K_
1.600000,9547,K_
1.800000,10164,K_
2.000000,10532,K_
2.200000,9999,K_
2.400000,10914,K_
2.600000,10381,K_
2.800000,8854,K_
3.000000,9110,K_
3.200000,10085,K_
3.400000,10805,K_
3.600000,10565,K_
3.800000,10230,K_
4.000000,10681,K_
4.200000,11174,K_
4.400000,15618,K_
4.600000,15747,K_
4.800000,15723,K_
5.000000,15718,K_
5.200000,15722,K_
5.400000,15719,K_
5.600000,15909,K_
5.800000,16077,K_
6.000000,15963,K_
6.200000,15960,K_
6.400000,15960,K_
6.600000,15960,K_
6.800000,15960,K_
It's slice based encoding, instead of one slice for each picture, it uses 8 slices for each picture.
I must apologise for the very late reply. Thank you for the help so far. When you have a frame which has multiple slices, what do the NALU's look like? Are all 8 slices prefixed with 0x65 to indicate they are key frames, or is it only the first?
Edit: I've found the answer to my own question. It looks like multiple slices both have their own 0x65's, but they aren't prefixed by a 0x67, 0x68 like the first slice of the IDR frame isLast edited by TheOmbudsman; 26th Jul 2022 at 06:08.
No, they can't be prefixed with 0x67, 0x68 (sequence parameter set and picture parameter set) because slices are part of one picture, if that's what you are asking.
ffmpeg MKV to MP4 error track 1: codec frame size is not set
By Anonymous543 in forum Newbie / General discussionsReplies: 23Last Post: 4th Mar 2022, 07:06 -
Browser video player frame size problem
By jgg in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2021, 12:13 -
Problem with Premiere frame size and motion scale on frame hold
By miguelmorin in forum EditingReplies: 0Last Post: 10th Jan 2021, 17:20 -
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 22:41 -
Remove strange overlay from vob converted to mp4?
By LodovicoAriosto in forum Video ConversionReplies: 9Last Post: 22nd Oct 2018, 01:35
