    Apr 2011
    bristol
    so keep getting errors with these files not finishing encoding without errors and need your help in solving what the issue is-as even tried other sources and get same ending with errors-here is log below- i do also have the batchmux file uploaded below the normal one
    thanks for help in advance
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "D:\AppData\Local\Temp\DVD_BatchMux.ini"
    BatchMux ini file:
    -bmlog "D:\AppData\Local\Temp\DVD_BatchMux.log"
    -d "D:\Users\User\Videos\DVD\VIDEO_TS"
    -mxp "D:\AppData\Local\Temp\DVD_MuxMan.mxp"
    -l "D:\AppData\Local\Temp\DVD_MuxMan.log"
    -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
    -prio NORMAL
    -palette "D:\AppData\Local\Temp\DVD_Palette.txt"
    -v "D:\Users\User\Videos\DVD_Title_01_ob-3.m2v"
    -vidmode LB
    -a1 "D:\Users\User\Videos\DVD_Title_01_ob-3_1.ac3"
    -a1lang en
    -s1 "D:\Users\User\Videos\DVD_Title_01_ob-3_1.sup"
    -s1lang en
    -s1ext 1
    -s2 "D:\Users\User\Videos\DVD_Title_01_ob-3_2.sup"
    -s2lang en
    -s2ext 1
    -cellfr "D:\Users\User\Videos\DVD_Title_01_ob-3_Chapters.txt"
    -progfr "D:\Users\User\Videos\DVD_Title_01_ob-3_Chapters.txt"
    -chapfr "D:\Users\User\Videos\DVD_Title_01_ob-3_Chapters.txt"
    -SEG2v "D:\Users\User\Videos\DVD_Title_02_ob-4.m2v"
    -SEG2vidmode LB
    -SEG2a1 "D:\Users\User\Videos\DVD_Title_02_ob-4_1.ac3"
    -SEG2a1lang en
    -SEG2s1 "D:\Users\User\Videos\DVD_Title_02_ob-4_1.sup"
    -SEG2s1lang en
    -SEG2s1ext 1
    -SEG2s2 "D:\Users\User\Videos\DVD_Title_02_ob-4_2.sup"
    -SEG2s2lang en
    -SEG2s2ext 1
    -SEG2cellfr "D:\Users\User\Videos\DVD_Title_02_ob-4_Chapters.txt"
    -SEG2progfr "D:\Users\User\Videos\DVD_Title_02_ob-4_Chapters.txt"
    -SEG2chapfr "D:\Users\User\Videos\DVD_Title_02_ob-4_Chapters.txt"
    -SEG3v "D:\Users\User\Videos\DVD_MenuPage1.bmp"
    -SEG3vidmode LB
    -SEG3s1 "D:\Users\User\Videos\DVD_Menu.sst"
    -SEG3s1dmode WIDE_LB
    -SEG3hlmnu "D:\AppData\Local\Temp\DVD_MenuPage1_Buttons.m nu"
    -SEG3hlcsm "D:\AppData\Local\Temp\DVD_HighlightScheme.csm
    -hcn "D:\AppData\Local\Temp\DVD_BatchMux.hcn"
    <04/07/2022 21:28:36>
    Process aborted during DVD AUTHORING finalization!
    Check following files for more details:
    AVStoDVD log file <D:\Users\User\Videos\DVD.log>
    BatchMux log file <D:\Users\User\Videos\DVD_BatchMux.log>
    For more troubleshooting on Authoring issues, see Help/FAQ/Authoring.
    <04/07/2022 21:29:37>
    Warning! AVStoDVD Project ended with errors.
    Log file created by AVStoDVD Release 2.8.9
    batchmux file
    BatchMux log file --> D:\AppData\Local\Temp\DVD_BatchMux.log
    BatchMux version --> 1.4.1
    Destination Folder --> D:\Users\User\Videos\DVD\VIDEO_TS
    MuxMan Script File --> D:\AppData\Local\Temp\DVD_MuxMan.mxp
    MuxMan Log String --> -l "D:\AppData\Local\Temp\DVD_MuxMan.log"
    Folder of the MuxMan executable --> C:\Program Files (x86)\AVStoDVD\MuxMan
    Check presence of MuxMan.exe --> PASSED
    Palette File --> D:\AppData\Local\Temp\DVD_Palette.txt
    Default Palette --> SUCCESSFULLY REDEFINED
    Segment #1 - Video File #1 --> D:\Users\User\Videos\DVD_Title_01_ob-3.m2v
    Checking asset for importing as --> M2V, M1V, MPV
    Video Coding Mode --> MPEG-2
    Video Resolution (Nominal) --> (720x576)
    MPEG-2 Aspect Ratio (DAR) --> 16:9
    Video Frame Rate --> 25 fps
    Video Bitrate (Nominal, Kbps) --> 8789
    VBV Buffer Size (Kbyte) --> 224
    Segment #1 - Video Display Mode --> LB
    Segment #1 - Audio #1 File #1 --> D:\Users\User\Videos\DVD_Title_01_ob-3_1.ac3
    Segment #1 - Audio Lang Code #1 --> en
    Segment #1 - Subpicture File #1 --> D:\Users\User\Videos\DVD_Title_01_ob-3_1.sup
    Segment #1 - Subpicture File #2 --> D:\Users\User\Videos\DVD_Title_01_ob-3_2.sup
    Segment #1 - Subpic Lang Code #1 --> en
    Segment #1 - Subpic Lang Code #2 --> en
    Segment #1 - Subpic Lang Ext #1 --> 1
    Segment #1 - Subpic Lang Ext #2 --> 1
    Segment #1 - Timeframe file --> D:\Users\User\Videos\DVD_Title_01_ob-3_Chapters.txt
    Segment #1 - Total Nr of Cells --> 6
    Segment #1 - Total Nr of Programs --> 6
    Segment #1 - Total Nr of Chapters --> 6
    Segment #2 - Video File #1 --> D:\Users\User\Videos\DVD_Title_02_ob-4.m2v
    Segment #2 - Video Display Mode --> LB
    Segment #2 - Audio #1 File #1 --> D:\Users\User\Videos\DVD_Title_02_ob-4_1.ac3
    Segment #2 - Audio Lang Code #1 --> en
    Segment #2 - Subpicture File #1 --> D:\Users\User\Videos\DVD_Title_02_ob-4_1.sup
    Segment #2 - Subpic Lang Code #1 --> en
    Segment #2 - Subpic Lang Ext #1 --> 1
    Segment #2 - Subpicture File #2 --> D:\Users\User\Videos\DVD_Title_02_ob-4_2.sup
    Segment #2 - Subpic Lang Code #2 --> en
    Segment #2 - Subpic Lang Ext #2 --> 1
    Segment #2 - Timeframe file --> D:\Users\User\Videos\DVD_Title_02_ob-4_Chapters.txt
    Segment #2 - Total Nr of Cells --> 6
    Segment #2 - Total Nr of Programs --> 6
    Segment #2 - Total Nr of Chapters --> 6
    Segment #3 - Video File #1 --> D:\Users\User\Videos\DVD_MenuPage1.bmp
    Checking asset for importing as --> BMP
    Image size --> (720x576)
    Image asset --> ACCEPTED
    Segment #3 - Video Display Mode --> LB
    Segment #3 - Subpicture File #1 --> D:\Users\User\Videos\DVD_Menu.sst
    Segment #3 - Subpic Disp Mode #1 --> WIDE_LB
    Segment #3 - HL Play Item #1 MNU File --> D:\AppData\Local\Temp\DVD_MenuPage1_Buttons.mnu
    Segment #3 - HL Play Item #1 NumButtons --> 3
    Segment #3 - HL Play Item #1 NumGroups --> 2
    Segment #3 - HL Play Item #1 G1 Button Mode --> WIDE
    Segment #3 - HL Play Item #1 G2 Button Mode --> LB
    Imported Butt1 G1 posx --> 166
    Imported Butt1 G1 posw --> 160
    Imported Butt1 G1 posy --> 210
    Imported Butt1 G1 posh --> 128
    Imported Butt1 G1 adj_but_up --> 1
    Imported Butt1 G1 adj_but_left --> 1
    Imported Butt1 G1 adj_but_right --> 2
    Imported Butt1 G1 adj_but_down --> 3
    Imported Butt1 G1 color scheme --> 1
    Imported Butt1 G1 auto activate --> 0
    Imported Butt1 G1 command --> 71 04 00 00 00 01 00 02
    Button command interpreted as --> mov GPRM0, 1 ; LinkPGCN __CURRENT_DOMAIN_PGC__2
    Imported Butt1 G2 posx --> 166
    Imported Butt1 G2 posw --> 160
    Imported Butt1 G2 posy --> 229
    Imported Butt1 G2 posh --> 96
    Imported Butt1 G2 adj_but_up --> 1
    Imported Butt1 G2 adj_but_left --> 1
    Imported Butt1 G2 adj_but_right --> 2
    Imported Butt1 G2 adj_but_down --> 3
    Imported Butt1 G2 color scheme --> 1
    Imported Butt1 G2 auto activate --> 0
    Imported Butt2 G1 posx --> 393
    Imported Butt2 G1 posw --> 160
    Imported Butt2 G1 posy --> 210
    Imported Butt2 G1 posh --> 128
    Imported Butt2 G1 adj_but_up --> 2
    Imported Butt2 G1 adj_but_left --> 1
    Imported Butt2 G1 adj_but_right --> 3
    Imported Butt2 G1 adj_but_down --> 3
    Imported Butt2 G1 color scheme --> 1
    Imported Butt2 G1 auto activate --> 0
    Imported Butt2 G1 command --> 71 04 00 00 00 02 00 02
    Button command interpreted as --> mov GPRM0, 2 ; LinkPGCN __CURRENT_DOMAIN_PGC__2
    Imported Butt2 G2 posx --> 393
    Imported Butt2 G2 posw --> 160
    Imported Butt2 G2 posy --> 229
    Imported Butt2 G2 posh --> 96
    Imported Butt2 G2 adj_but_up --> 2
    Imported Butt2 G2 adj_but_left --> 1
    Imported Butt2 G2 adj_but_right --> 3
    Imported Butt2 G2 adj_but_down --> 3
    Imported Butt2 G2 color scheme --> 1
    Imported Butt2 G2 auto activate --> 0
    Imported Butt3 G1 posx --> 570
    Imported Butt3 G1 posw --> 104
    Imported Butt3 G1 posy --> 482
    Imported Butt3 G1 posh --> 45
    Imported Butt3 G1 adj_but_up --> 2
    Imported Butt3 G1 adj_but_left --> 2
    Imported Butt3 G1 adj_but_right --> 3
    Imported Butt3 G1 adj_but_down --> 3
    Imported Butt3 G1 color scheme --> 1
    Imported Butt3 G1 auto activate --> 0
    Imported Butt3 G1 command --> 71 04 00 00 00 01 00 02
    Imported Butt3 G2 posx --> 570
    Imported Butt3 G2 posw --> 104
    Imported Butt3 G2 posy --> 434
    Imported Butt3 G2 posh --> 34
    Imported Butt3 G2 adj_but_up --> 2
    Imported Butt3 G2 adj_but_left --> 2
    Imported Butt3 G2 adj_but_right --> 3
    Imported Butt3 G2 adj_but_down --> 3
    Imported Butt3 G2 color scheme --> 1
    Imported Butt3 G2 auto activate --> 0
    Segment #3 - HL Play Item #1 Force Selected Button Nr --> 0
    Segment #3 - HL Play Item #1 Force Activated Button Nr --> 0
    Segment #3 - HL Play Item #1 Selection End Time --> -1
    Segment #3 - HL Play Item #1 Nr of Selectable Buttons --> 3
    Segment #3 - HL Play Item #1 Color Scheme File --> D:\AppData\Local\Temp\DVD_HighlightScheme.csm
    Imported CSM #1 Select Color --> (E2 E1 PA BG) 10 10 10 10
    Imported CSM #1 Select Opacity --> (E2 E1 PA BG) 0 2 4 8
    Imported CSM #1 Action Color --> (E2 E1 PA BG) 7 7 7 7
    Imported CSM #1 Action Opacity --> (E2 E1 PA BG) 0 3 6 12
    Configuration File for HCN --> D:\AppData\Local\Temp\DVD_BatchMux.hcn
    HC Navigation - VMG MenuPages --> 1
    HC Navigation - VMG MenuType(1) --> STATIC
    HC Navigation - VMG TitleBut(1) --> 2
    HC Navigation - VMG PlayAllBut(1) --> 3
    Started preparation of --> MUXMAN SCRIPT
    Completed preparation of --> MUXMAN SCRIPT
    MuxMan RunString --> -run
    Strings (local stack - bytes) --> 2259
    Time Codes (local heap - bytes) --> 445
    Static memory usage % --> 2.06
    Starting MuxMan Authoring with --> NORMAL task priority
    MuxMan Authoring --> COMPLETE
    Printing out --> MUXMAN LOG
    -- MuxMan version 0.16.8
    -- Opened script file D:\AppData\Local\Temp\DVD_MuxMan.mxp
    -- Accepted audio D:\Users\User\Videos\DVD_Title_01_ob-3_1.ac3
    -- Opened sub 1 file D:\Users\User\Videos\DVD_Title_01_ob-3_1.sup.
    -- Opened sub 2 file D:\Users\User\Videos\DVD_Title_01_ob-3_2.sup.
    -- Accepted audio D:\Users\User\Videos\DVD_Title_02_ob-4_1.ac3
    -- Opened sub 1 file D:\Users\User\Videos\DVD_Title_02_ob-4_1.sup.
    -- Opened sub 2 file D:\Users\User\Videos\DVD_Title_02_ob-4_2.sup.
    -- Opened sub 1 file D:\Users\User\Videos\DVD_Menu.sst.
    -- expanded database to 300 entries.
    -- No useable audio found for PGC "VMG_Lu1_Pgc1"
    -- 21:27:55 Begin multiplex VTS01.
    -- Title Segment List
    -- Seg1
    -- Encoded stream 20 is script stream 1.
    -- Encoded stream 21 is script stream 2.
    -- Maximum audio duration 128388 fields.
    -- Starting scene Seg1_Scn1 at 00:00:00:00
    -- Starting scene Seg1_Scn2 at 00:00:03:22, requested for 00:00:03:21
    -- Starting scene Seg1_Scn3 at 00:01:29:11, requested for 00:01:28:23
    -- Starting scene Seg1_Scn4 at 00:01:30:01
    -- Starting scene Seg1_Scn5 at 00:01:54:15, requested for 00:01:54:13
    -- Starting scene Seg1_Scn6 at 00:39:42:00, requested for 00:39:41:14
    -- SeqEnd at 7DC297FA.
    -- Bytes remaining in buffer = 0.
    -- Bitrate - avg: 7153266, min: 512000 (lba 0), max: 9693866 (lba 725969).
    -- Shortest GOP has 4 fields, longest GOP has 30 fields.
    -- Fields: 128384, VOBU: 4329, Sectors: 1121051.
    -- 21:28:17 Begin multiplex VTS02.
    -- Seg2
    -- Maximum audio duration 104662 fields.
    -- Starting scene Seg2_Scn1 at 00:00:00:00
    -- Starting scene Seg2_Scn2 at 00:00:03:22, requested for 00:00:03:21
    -- Starting scene Seg2_Scn3 at 00:01:28:12, requested for 00:01:28:04
    -- Starting scene Seg2_Scn5 at 00:01:53:02
    -- Starting scene Seg2_Scn6 at 00:33:17:24, requested for 00:33:17:19
    -- SeqEnd at 6249C6EA.
    -- Bitrate - avg: 6878679, min: 512000 (lba 0), max: 9693866 (lba 621319).
    -- Fields: 104658, VOBU: 3539, Sectors: 878795.
    -- Reference to non-existant scene "Seg2_Scn4" from PGC "VTS02_Ttn1_Pgc1"
    Dyn. allocated segment resources --> RELEASED
    --> 3 segments
    Dyn. allocated BmArg resources --> RELEASED
    --> 81 BmArg structures
    Local Stack memory --> RELEASED
    File i/o structures --> DEALLOCATED
    Mar 2008
    My first thought is that there is something wrong with one or more of the assets, I'd check the rest of the A2D log
    and/or post the complete log here
    Apr 2011
    bristol
    i have posted both complete logs ? both the batchmux log and the log file were posted on the above post ?
    Mar 2008
    I'm talking about the complete AvstoDVD log, it usually ends up in the "dvd output" path folder
    Apr 2011
    bristol
    ok will have to retry it and get that for you as must of deleted that one- as thought the two logs i posted was what i needed on here-will prob be later on now as takes ages to do
    Mar 2008
    Based on the muxman log, it looks like it was the second title that had problems.
    Perhaps run that by itelf and see what happens
