By the way: How did you create your .mp4 sources and samples?
- PAL or NTSC? 25fps or 30fps?
- Color matrix 601 or 709? Any conversion done at some point?
- What was the original format and resolution? Progressive or interlaced?
- Has it been reencoded and/or resized at some stage?
Edit:
Hmmm, my guessing is that these videos were taken with a mobile phone. Nominal framerate is 30 fps. So you should change the assumefps(25) in the beginning of the script by assumefps(30), or leave it away.
Results 31 to 36 of 36
That were just the orriginal, unedited files from my phone.
It's fps recording is set to 30fps, so NTSC if I'm correct?
So the resolution etc is orriginal too. -
All right. Just a brain fart. No offense. AssumeFPS(30) would be correct then.
The reason for my doubts were because MediaInfo reports different color primaries (BT.709, limited range versus "original" BT.601 PAL, BT. 470 System B/G, full range) for the .mp4 files
Maybe a stream versus container issue, or just how the mobile phone handles it ......
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 23 s 691 ms
Bit rate : 20.1 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.000 FPS
Minimum frame rate : 29.732 FPS
Maximum frame rate : 30.344 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.323
Stream size : 56.8 MiB (98%)
Title : VideoHandle
Language : English
Encoded date : UTC 2022-04-03 20:41:00
Tagged date : UTC 2022-04-03 20:41:00
Color range : Limited
colour_range_Original : Full
Color primaries : BT.709
colour_primaries_Original : BT.601 PAL
Transfer characteristics : BT.709
transfer_characteristics_Original : BT.601
Matrix coefficients : BT.709
matrix_coefficients_Original : BT.470 System B/G
mdhd_Duration : 23691
Codec configuration box : avcCLast edited by Sharc; 24th Jul 2022 at 05:20.
Oh, I don't know about that. It's a lot of information though haha. It were just the orriginal files copied straight from my phone.
I'm using this "AutoAdjust plugin" with saturation set to 1.1 a lot for improving the rest of my video's too now. I think it gives some nice automated results, close to the orriginal video colors. I think I've nearly corrected almost all my video's with this now.
It seems my phone camera tends to darken out spots really quickly, almost turning to black. While moving, but also blackening out the foreground. It's verry annoying actually. But luckily I can "repair" my other video's also a bit with this. I think it will be a good thing to look for a new phone with a better camera on my next trip...
This Avisynth is verry powerfull btw!
I should get more familiar with it.
Not sure where this belongs.. some video showing up "white / overexposed"..
By yuppicide0138 in forum EditingReplies: 6Last Post: 30th Nov 2021, 22:48 -
Restoring this messy telecine-interlaced video
By rrats in forum RestorationReplies: 12Last Post: 17th Oct 2021, 06:49 -
Restoring a badly degraded video with Avisynth?
By MediaHoarder in forum RestorationReplies: 24Last Post: 18th Feb 2021, 15:28 -
Restoring telecined video
By semel1 in forum Newbie / General discussionsReplies: 13Last Post: 2nd Feb 2021, 09:57 -
when restoring with film9 the result is video +-10frames/s instead of 18
By efect2000 in forum RestorationReplies: 8Last Post: 29th Jul 2019, 14:21
