    Jul 2022
    France
    hello,
    Since two days, Dumper works half i explain :
    the program dump just 3 things : license_request.bin, 4445.bin and 4445.json
    Android 9 and samsung galaxy S8PLUS
    I don't know how will do for get all files
    Thanks you in advance.
  2. Originally Posted by Zaito View Post
    hello,
    The script isn't something that works half... it wither works and dumps the correct files, or it doesn't work and gives errors or wrong files.
    Anyway.. you issue is likely to be the functions that are being hooked. You need to find the correct functions in the libwvhidl.so file and edit the script.js file
    Jul 2022
    France
    Where i can find the libwvhidl.so in the android direct in phone or in dumper ?
    Thank you for your response.
    (I HAVE FIND!)
