Hello everyone For almost a whole month now I have been trying to download a file from a specific site
This is the link to the video
https://www.karaoke.co.il/api_play.php?type=clip&id=58370&autoplay=undefined&referer=karaoketv
The M3u8 files are split into 2 parts.
Video file
https://www.video-cdn.com/video/encrypt/750802ea0bc2d02fac93adeaa1398ec2/750802ea0bc2d...2-57d9518fae69
And an audio file
As far as I know there is a Key that needs to be entered in order to download the file.
And when I run the command in ffmpeg
I encounter many errors like:
Unable to open key file
Anyone who can download it.
I would be very happy if he would write me a code that works and explain to me how to do it
These are all the codes I have already tried
Code:ffmpeg -decryption_key https://www.video-cdn.com/video/key/750802ea0bc2d02fac93adeaa13cde64 -i https://www.video-cdn.com/video/encrypt/750802ea0bc2d02fac93adeaa1398ec2/750802ea0bc2d02fac93adeaa1398ec2/video_720p.m3u8?token=R915dD-72351a7c-3dd1-4e58-b6c2-9cc813eeb183 -vcodec libx264 {output_file} ffmpeg -decryption_key {key} -i {file} -max_muxing_queue_size 9999 d.mp4 ffmpeg -allowed_extensions ALL -protocol_whitelist data, file, http, https, tcp, tls, crypto -i "https://www.video-cdn.com/video/encrypt/f242d2da41d03b3955fb866efc5dbd59/f242d2da41d03b3955fb866efc5dbd59/video_720p.m3u8?token=R915dD-a1430cfc-0bda-46a0-a7e9-b15308875dc7" c copy -bsf: a aac_adtstoasc test.mp4 -decryption_key C:\ ffmpeg\enc.key hlsdl -K "1a9625fb34a4afe0d5446138e9543563" https://www.video-cdn.com/video/encrypt/f242d2da41d03b3955fb866efc5dbd59/f242d2da41d03b3955fb866efc5dbd59/video_720p.m3u8?token=R915dD-be07b7e6-08aa-441b-afbd-5c7876409878
Results 1 to 17 of 17
I don't know how you got that key used with the hlsdl command but your correct key is this one
You can get the key with curl and getting the contents of the following link, output to whateverCode:CCF7E3874FE0D3D10A8CF212E30DFB2A
and open the whatever file with a hex editor. That's the key.Code:curl https://www.video-cdn.com/video/key/750802ea0bc2d02fac93adeaa1398ec2 --output whatever
streamlink --hls-segment-key-uri "https://www.video-cdn.com/video/key/750802ea0bc2d02fac93adeaa1398ec2" "hls://www.video-cdn.com/video/encrypt/750802ea0bc2d02fac93adeaa1398ec2/128default?token=R915dD-1045eac7-9a29-4c92-9fa9-aac7b89ba92e" best -o video.ts
[cli][info] Found matching plugin hls for URL hls://www.video-cdn.com/video/encrypt/750802ea0bc2d02fac93adeaa1398ec2/128default?token=R915dD-1045eac7-9a29-4c92-9fa9-aac7b89ba92e
[cli][info] Available streams: 480p (worst), 720p (best)
[cli][info] Opening stream: 720p (hls-multi)
[cli][info] Writing output to
video.ts
[utils.named_pipe][info] Creating pipe streamlinkpipe-7660-1-2212
[utils.named_pipe][info] Creating pipe streamlinkpipe-7660-2-4751
[download][b.ts] Written 7.0 MB (6s @ 1.1 MB/s) ... -
.... Or a one liner for Linux users:-
Code:curl https://www.video-cdn.com/video/key/750802ea0bc2d02fac93adeaa1398ec2 | od -A n -t x1 |sed 's/ //g'
[Attachment 65911 - Click to enlarge] -
Hi [ss]vegeta, here are the windows commands
ORCode:curl -k https://www.video-cdn.com/video/key/750802ea0bc2d02fac93adeaa1398ec2 | xxd -ps -c 200
Code:curl -k https://www.video-cdn.com/video/key/750802ea0bc2d02fac93adeaa1398ec2 | od -A n -t x1 | sed "s/ //g"
[Attachment 65915 - Click to enlarge] -
This is the .m3u8 file I have:
https://d2s2mc5mfsrgxi.cloudfront.net/spees/w/o/607d7f740cf265c8e0215b0d/v/62e3d70c0cf...3/hls_1M_.m3u8
URI="k/timestamp"
I have a lot of such videos to download. Could someone here please tell me how to do so? @LZAA bro if you can tell me the method. If I am not wrong, you had converted a similar video back in 2017. -
akshaysic ==> anandgpt75 ==> unstable ==> AkshatLal
All the same refrain
URI="k/timestamp" ...... I have a lot of such videos to download. -
Please help me find the key rest i will do on my own , just help me get the key
this is the m3u8 file
https://dnqe0v482iyb1.cloudfront.net/spees/w/o/60e975430cf20278db21ff30/v/647d8964e4b0...561/index.m3u8
its info
#EXTM3U
#EXT-X-VERSION:3
#EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="audio-0",NAME="eng",LANGUAGE="eng",DEFAULT=YES,AUTOSELEC T=YES,URI="hls_audio_.m3u8"
#EXT-X-STREAM-INF:AUDIO="audio-0",BANDWIDTH=650000,CODECS="avc1.64001f,mp4a.40.2" ,RESOLUTION=852x480
hls_500k_.m3u8
#EXT-X-STREAM-INF:AUDIO="audio-0",BANDWIDTH=900000,CODECS="avc1.64001f,mp4a.40.2" ,RESOLUTION=1280x720
hls_1M_.m3u8
#EXT-X-STREAM-INF:AUDIO="audio-0",BANDWIDTH=1500000,CODECS="avc1.640028,mp4a.40.2 ",RESOLUTION=1920x1080
hls_2M_.m3u8
i want key for hls_2m_.m3u8
hls_2m_.m3u8 file info:
#EXTM3U
#EXT-X-VERSION:3
#EXT-X-TARGETDURATION:3
#EXT-X-MEDIA-SEQUENCE:0
#EXT-X-KEY:METHOD=AES-128,URI="k/timestamp",IV=0x496daa1c6914000e408c65cead91fc29
#EXTINF:2.000000,
hls_2M_000.ts
#EXTINF:2.000000,
hls_2M_001.ts
#EXTINF:2.000000,
.................................. its a big file having lots of ts file
so i think required info is
and link for file i want to download => https://dnqe0v482iyb1.cloudfront.net/spees/w/o/60e975430cf20278db21ff30/v/647d8964e4b0...1/hls_2M_.m3u8
Plz help , thanks in advance
Download encrypted m3u8 with available key
By ao8vofa8usibfd in forum Video Streaming DownloadingReplies: 17Last Post: 6th Apr 2021, 16:58 -
How to download aes encrypted m3u8?
By Cluelessidiot in forum Video Streaming DownloadingReplies: 6Last Post: 4th Oct 2020, 15:12 -
How to download encrypted .m3u8 videos? HELP!
By AngelofDarkness in forum Video Streaming DownloadingReplies: 10Last Post: 21st Sep 2018, 18:17 -
By AngelofDarkness in forum Newbie / General discussionsReplies: 0Last Post: 20th Sep 2018, 19:04
