Results 1 to 1 of 1
  1. Hi,
    I have now managed with your help to decrypt the stream and would now like to stream it unencrypted. The problem is that it often comes to buffering. I try that with the following command but it helps nothing. I see in the log of FFMPEG that the speed falls below 1x which is probably not good and an error I do not know how to fix. How do I solve the problem?
    https://forum.videohelp.com/threads/406330-Widewine-Key-request-problem
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x85c9180] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x6cb94c0] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x8763b00] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x85a2500] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x79afc00] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x84d1b40] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7621b00] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x8141840] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x85d5440] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x85c8f40] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x8613b00] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x9c75280] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0xb5d0900] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x7c37480] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x85b2780] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x84cc180] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x6c24b80] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0xa26fa40] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x81c42c0] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x84e58c0] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0xb5872c0] Failed to seek for auxiliary info, will only parse senc atoms for encryption info
    frame= 9789 fps= 36 q=-1.0 size=   60363kB time=00:03:19.72 bitrate=2475.9kbits/s speed=0.726x
    Streaming Command
     ffmpeg -cenc_decryption_key 99e4e9f783edf3fc22d063afb0402667 -report -rtbufsize 2000M -xerror -timeout 10000 -fflags +genpts -async 1 -re -probesize 100000000 -analyzeduration 100000000 -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:81.0) Gecko/20100101 Firefox/81.0" -i "https://svc40.main.sl.t-online.de/LCID3221228143.originalserver.prod.sngtv.t-online.de/PLTV/88888888/224/3221228143/3221228142CEND&GuardEncType=2"  -vcodec copy -acodec copy -scodec copy -f flv rtmp://localhost/test/test
    It often works well and displays 1x speed only he has then at some point again problems...
