Hi
How can I setup potplayer to use GPU instead of CPU?
I want to play a 2160p video and it uses a lot of CPU.
I always set mine to use DXVA: Preferences, Filter Control, Video Decoder, Built-in video codec/dxva settings... Check Use DXVA, enable all VLD... I also use the Direct3D11 video renderer. Click "Tab" while playing a video to see stats.
Also under Filter Control, OpenCodec, you might want to enable all the decoders.
I only have an older 1080p TV, so I never played higher resolution videos to check. -
Thank you for answers.
I have an old GTX 1050 TI video card. But with today prices is better than nothing. -
Make sure the codec, color format, bit depth, and frame size are supported. AV1, for example. isn't supported by the 1050 Ti.
https://developer.nvidia.com/video-encode-and-decode-gpu-support-matrix-new
How do I maximise GPU/CPU usage when converting to x264?
By daklone in forum Video ConversionReplies: 1Last Post: 17th Aug 2021, 17:03 -
GPU or CPU encoding?
By m00511 in forum Newbie / General discussionsReplies: 44Last Post: 17th Nov 2019, 20:03 -
Potplayer + MadVR, GPU usage is halved when resized or fullscreen?
By Rumba47 in forum Software PlayingReplies: 0Last Post: 10th Jun 2018, 15:58 -
HEVC or H264 GPU vs CPU Another time !!!
By gringito38 in forum Video ConversionReplies: 2Last Post: 23rd Feb 2018, 06:28 -
There is too much about GPU vs CPU encoding, but how about GPU filters?
By Bernix in forum Newbie / General discussionsReplies: 24Last Post: 16th Feb 2018, 17:17
