I'm at a loss for how to troubleshoot this. I am backing up DVDs of old videos (personally filmed recitals/performances, no DRM issues) into digital format, and this particular DVD has no read errors when I decrypt it with DVDDecrypter. All the VOBs copy over without any issues. But when I open it in VLC, it skips/stutters a lot, and any attempt to convert it obviously results in videos with stutters/skipping as well.
I've cleaned the DVD surface (though I'm not sure if that's the problem, if there are no read errors?), I've tried different software: Handbrake, MakeMKV, DVDDecrypter, and they all result in the same issue.
Any idea what could be wrong? I've watched this DVD before (more than 5 years ago so it's been awhile) and it definitely worked properly at one point. But I have no idea what went wrong and how I can fix the problem now.
I am open to trying video editing software that's capable of repairing the issue as well.
Results 1 to 17 of 17
If no DRM is involved, you can also try clever FFmpeg-GUI for ripping.
Point to VTS_aa_1.VOB (where aa ist the desired title set, g.e. VTS_01_1.VOB), answer Yes to the question, and the full Movie will be ripped to VOB.Last edited by ProWo; 13th Jul 2022 at 06:20.
Thanks all for the suggestion! Tried all 3 but I'm still getting the same skipping on the disc. :-\ I don't know if my next option should be to look into video repair software (if they exist) or if I'm just out of luck. I've been storing these DVDs in a sleeve/case and thought they'd be safe, but maybe they degraded too much over the years.
Did you rule out the drive /reader ? Does the DVD play ok in a normal standalone DVD player / TV ?
I no longer have a DVD player, but I tried it in my PC's DVD drive, and I also recently bought an external DVD drive. I'm getting the same issues with both.
Best to try in a home dvd player connected to a tv as poisondeathray suggested,playing the dvd in your computer could be causing the issues due to hardware/software issues.
It is a possibility that this DVD disk has degraded.
How do other DVDs play on your computers drives ?
If they play OK then your drives should not be the problem.
I have one other software to suggest.
It will do a bit by bit extraction.
You will need to mount the .ISO it creates in a virtual drive.
Then you can burn it to DVD.
Or if it is 4.35GB or smaller ImgBurn will burn the .ISO to a DVD.
IsoPuzzle-17Beta :
On this site
https://www.videohelp.com/software/IsoPuzzle/old-versions
I'm uploading my portable if you want it.
It already has the Read Me translated to English & the WNASPI32.DLL.
The download from videohelp.com doe not have these.
The download from videohelp.com does have the Read Me in German.
The program needs the WNASPI32.DLL to work. -
When you first burned the disc did you watch the whole thing or just a bit?
I watched the whole thing through once and haven't touched it since. I'm only now beginning the process of digitizing all my recordings as backups and ran into this strange issue just now. I definitely have a few discs that can't even be copied anymore, but I was a little more hopeful about this one because it didn't throw any read errors or warnings at all when I copied it over.
Since the ISOPuzzle .ISO played with skips/stutters I now believe the problem is a deteriorated DVD disk.
More so if you loaded the .iso in a virtual drive.
Which should eliminate the DVD entirely.
ISOPuzzle is supposed to do a bit by bit rip.
I have had it fail to finish a DVD because it wouldn't copy all the bits.
If it finished & the disk is having problems it should be a deteriorated disk.
The dyes used do break down over time.
What brand is this DVD ?
You can rip the DVD format folders from the virtual drive & try the Flash drive as suggested but I believe the results will be the same. -
VOB files aren't necessarily playable by themselves (they can, for example, have other data in them that a player can't handle properly). You may need to include the IFO files and use DVD player software that parses them. Try using a player like VLC and it's Open Disc or Open Folder options.
There are a couple of more steps you could take.
No guarantee this will help but it might.
Use the ISOPuzzle rip to an .iso.
Mount that .iso in a virtual drive.
There are at least 2 that are freeware:
elaborate bytes virtual clonedrive
https://www.elby.ch/en/products/vcd.html
DVDFab Virtual Drive
https://www.dvdfab.cn/virtual-drive.htm
From one of the virtual drives open the DVD files in Vob2mpg-v3.
https://www.videohelp.com/software/VOB2MPG
See if the .mpg or .mpgs it creates play on your media player like VLC .
Then if you want it back in DVD Format load the Title_1.mpg & other titles if it creates more in AVStoDVD.
This will be an encode & takes a while.
AVStoDVD should use HCEnc to do the encode.
IF larger than DVD5 makes sure to set AVStoDVD to DVD9.
Unless you want a compressed DVD to burn to single layer.
If already DVD5 size then it doesn't matter.
https://www.videohelp.com/software/AVStoDVD
Anyway to tell if a video was ripped from BluRay?
By guy24s in forum Blu-ray RippingReplies: 3Last Post: 6th Aug 2021, 11:10 -
DVD Decrypter: no Read Errors, but Retries?
By guy24s in forum DVD RippingReplies: 2Last Post: 27th May 2020, 13:37 -
Software to repair/fix video shutters/skips/lags
By kalemvar1 in forum Video ConversionReplies: 2Last Post: 13th May 2020, 17:33 -
Video file stutters
By blinkHQ in forum RestorationReplies: 3Last Post: 31st Mar 2020, 13:30 -
Video streams stutters in Firefox, Vivaldi, Opera but not in Chrome?
By rv93 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2019, 05:40
