I'm trying to extrat subs from a video that displayes the sub like karaoke: characters are displayed in sequence -one character after one. The speed of the sequence varies. I am missing quite a bit of the subs. Is there a way for me to set the intervals for sub recognition to be shorter? Or any other tips on how to capture such subs?
Thanks!
Results 1 to 1 of 1
VideoSubFinder - "Create Sub" function doesn't seem to work. [solved]
By Spiny Norman in forum SubtitleReplies: 1Last Post: 9th Nov 2021, 11:40 -
"Simple" Help Needed With Vertical Orientation
By GLSmyth in forum EditingReplies: 25Last Post: 21st Nov 2020, 17:14 -
How to bulk remove "style" (or dual language subtitle for that matter)
By shadiow in forum SubtitleReplies: 1Last Post: 4th Sep 2020, 12:20 -
HELP NEEDED: Is there an easy way to take away "screen refresh"?
By sapien68 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2019, 11:29 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 07:25
