I have a problem converting a 2CD divx movie to 2 svcds since when trying to encode one cd it says that the avi is more than 140 mins long (while it is 40 mins in fact) and so I cannot encode... any1 knows how to solve this ??
Results 1 to 9 of 9
I've got the same problem, and i don't know how to solve it aswell.. I hope somebody does it
divx5?
... this copy of me hasn't been registered for the last 36 years! (no spamming please) -
or nandub?
don't know, it's DivX allright. Don't know which version, but most groups still use DivX3.11. ... I've got DivX4or5 installed.
Maybe i must use the 3.11-codec..?? -
have you tried to increase the directshow reader priority and then open the divx?
i know tmpgenc does not work properly with some avi's due to the codec or lack of, directshow filters are a no go, i guess
two symptoms often show up: 1. audio is missing 2. result is much too long
there's no way around it, afaik, but perhaps someone found a solution?
what i use these days (when things go wrong) is export the audio, and set start and end point in tmpgenc by hand
if you are converting from divx film to pal vcd, you have to mess around with the audio anyway... this copy of me hasn't been registered for the last 36 years! (no spamming please) -
Originally Posted by doll2k
avisource("c:\path\file.avi")
Vob size 1048507kb, but in converter shows zero lenght?!
By Bumbledor in forum DVD RippingReplies: 7Last Post: 30th Apr 2012, 08:37 -
Getting the best results from TMPGEnc 2.5 on 2 AVIs
By buddycat in forum Video ConversionReplies: 28Last Post: 7th Nov 2010, 17:30 -
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 8th May 2010, 23:16 -
BD to MKV fix lenght
By cormiodo in forum Blu-ray RippingReplies: 7Last Post: 27th Nov 2009, 04:33 -
how do i check the audio and video lenght?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:51
