    Dec 2005
    Canada
    I'm trying to convert x265 video to x264, copying the audio and the subtitles (vobsub).
    The video is converted and the audio is copied ok, but the subs are missing.
    I listed the results from ffprobe and the command line used for the conversion.
    ffprobe:
    Input #0, matroska,webm, from '1.mkv':
    Metadata:
    creation_time : 2022-05-12T17:49:26.000000Z
    ENCODER : Lavf58.76.100
    Duration: 00:44:48.30, start: 0.000000, bitrate: 1140 kb/s
    Stream #0:0: Video: hevc (Main), yuv420p(tv, smpte170m/bt470bg/bt709), 720x406 [SAR 1:1 DAR 360:203], 25 fps, 25 tbr,
    1k tbn (default)
    Metadata:
    DURATION : 00:44:48.301000000
    Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
    Metadata:
    title : Stereo
    DURATION : 00:44:48.213000000
    Stream #0:2(eng): Subtitle: dvd_subtitle, 720x576
    Metadata:
    DURATION : 00:43:11.405000000
    ffmpeg -i 1.mkv -filter_complex "[0:v:0][0:s:0]overlay[v]" -map "[v]" -map 0:a:0 -acodec copy -c:v libx264 -crf 18 output.mkv
  2. I don't use vobsubs but I suspect they are being rendered below the bottom of the frame. Note the subs are 720x576 but the video is only 720x406. Try resizing the video to 1024x576 instead.
  3. Code:
    -scodec copy
    should tell ffmpeg to also copy the subtitles,...
  4. I think you're right. I thought the ffprobe report was of the new file he created. But it's of his hevc source.
    Dec 2005
    Canada
    Thanks to both.
    @jagabo, resizing didn't do it.
    The subtitles being a larger resolution than the video, is that normal?
    @Selur, changed the command and it worked (I had to add the extra map command before -scodec copy.
    The logic of the map and overlay commands elude me.
    ffmpeg -i 1.mkv -filter_complex "[0:v:0][0:s:0]overlay[v]" -map "[v]" -map 0:s:0 -scodec copy -map 0:a:0  -acodec copy -c:v libx264 -crf 18 output.mkv
