Results 1 to 30 of 43
    Jul 2022
    Spain
    Deleted.
    Jan 2016
    What's the reason for adding Cypress CTB-100?
  3. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    Yeah, the DMR-ES15 should be enough…. otherwise get a ES35V from ebay.
    My guess ….your Seagate 1TB HDD CMR SATA is too slow for uncompressed capturing
  4. Member Skiller's Avatar
    Oct 2013
    Germany
    The first two timing option tick boxes should always be checked (=enabled).
    I agree there is no point adding the Cypress CTB-100 after the ES15.
    Better use either one but not both.
    May 2005
    PAL User
    Because LS says we need a frame TBC as well as a line TBC.
  6. Member Skiller's Avatar
    Oct 2013
    Germany
    Right, that may apply to Line-TBCs built into VCRs, but I have yet to see how a frame TBC would yield an improvement in a scenario like this one – considering the output of Panasonic DVD-recorders has the original sync pulses of the VHS source replaced with perfect new ones. For anything after the Panasonic the signal looks pristine with nothing left to correct.
    May 2005
    PAL User
    I'll have to defer to the expert on that, Skiller. I just do what I am told!
    That said, if I understand LS's position correctly, the frame TBC is necessary to keep the A and V synched.
  8. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    I never did understand the difference between frame and line TBC's, never had problems in my setup, how does one see, which one is missing to need the one or the other ?
    I think one should also keep the differences in mind between PAL and NTSC, consumer devices can also have "baked in" faults, or different analog levels.(of any kind)
    (Japan IRE=0 US IRE=7.5 PAL IRE=0) (Spain = PAL) (Australia = PAL)
    May 2005
    PAL User
    The evidence of the line TBC is pretty obvious: the wobbly sides.
    The frame TBC helps with the AV sync.
    I've captured plenty of tapes without a frame TBC with no sync issues. Of course, with the (our) ES-35 and EZ-48, the strong "stabiliser" looks after the wobbles nicely.
    Jul 2022
    Spain
    With the DMR-ES15 I haven't had any a/v synchronization problems, it has also fixed some tapes that produced jitter.
  11. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    Thankyou, Alwyn.
  12. Capturing Memories dellsam34's Avatar
    Jan 2016
    This YouTube member demonstrated that some VCRs' line TBC is good enough to prevent even frame sync issues and frame drops, I'm not suggesting this is always the case or the card demonstrated is good, although I read positive reviews about it.
    @ Eric-jan in response to your question about line TBC, watch to the end of the clip where the line timing errors are circled in orange.
    https://youtu.be/SFpkNUoq-ac
  13. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    I have no problems with any vhs tape or source with my DMR-ES35V - Intensity Shuttle combination, no sync issues with long recordings, but now i use only BMD hardware, since no TBC is needed, also no PC/MAC needed for capture i record onto SD or (T5)SSD also with BMD hardware recorders.
    Thankyou for the example !
    btw. i now discovered that the TBC like function was called "VHS refresh" which some of the Panasonic combo's or recorders had build in.
    Jul 2022
    Spain
    Deleted.
  15. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    Like said the Cypress CTB-100 is not needed your problem lies in that you have slow storage during your capture.
    optimize one PC…. or use (stronger?) compression codec during capture.
    Jul 2022
    Spain
    Deleted.
  17. Capturing Memories dellsam34's Avatar
    Jan 2016
    We know the CTB-100 was the problem, Why did you remove the Panasonic DMR-ES15? Didn't you say you had no problems with this setup before adding the CTB-100? Put it back in and let us know what happens.
  18. Member
    Jul 2022
    Spain
    Deleted.
  19. Capturing Memories dellsam34's Avatar
    Jan 2016
    Oh I see. Are you capturing via USB2 or USB3?
    Jul 2022
    Spain
    Deleted.
  21. Capturing Memories dellsam34's Avatar
    Jan 2016
    Try your newer computer using USB3, capture over an hour, make sure all background activities are disabled and report back. USB2 speed is right at the edge of lossless capturing bandwidth, despite the advancement of CPU, memory and storage, the USB2 speed hasn't changed, It is not always the culprit but sometimes it is especially when a TBC is in the chain and yet the problem persists.
  22. Member
    Jul 2022
    Spain
    Deleted.
  23. Capturing Memories dellsam34's Avatar
    Jan 2016
    There is a data bottleneck somewhere that you need to figure out, and the only way to figure it out is by experimenting and trying out different capturing methods, ports, capture software, and sometimes even different capture devices. It is the nature of the beast.
  24. Member
    Jul 2022
    Spain
    Deleted.
  25. Capturing Memories dellsam34's Avatar
    Jan 2016
    The goal is to always have 0 frames but very few in a 2 hour video are not going to matter.
  26. Member
    Jul 2022
    Spain
    Deleted.
  27. Capturing Memories dellsam34's Avatar
    Jan 2016
    What do you mean by jitter, and how that is related to audio/video de-sync?
    If audio drift was caused by dropped/added frames the TBC would have fixed it, We've already established that. You have other data problems somewhere as I said before.
  28. Member
    Jul 2022
    Spain
    Deleted.
  29. Member
    Jul 2022
    Spain
    Deleted.
  30. Member Skiller's Avatar
    Oct 2013
    Germany
    Post a screenshot of the VD capture window during a capture but after it had been capturing for a couple of minutes. I'm interested in the stats on the right side of the window. Press the "Print" key next to F12 to do so, and then paste it in MS Paint, save as PNG. No need to use a camera.
    While we are at it, why not enable the timing graph ("Capture" -> "Timing graph").
    Have you tried enabling the first two timing settings?
    Are you using audio preview during capture?
    If yes, disable it (uncheck "Audio" -> "Enable audio playback")
    Edit: You could also try disabling video preview during capture. I always do that as I found it can be troublesome sometimes. The video can be better monitored on a TV anyways. "Capture" -> "Hide display on capture".
    Disconnect from the local network/internet during capture by disabling the network device and stop anything running in the background, including virus scanners.
    If none of that helps, heck, enable audio resync in VD. It should not be needed for the 600 USB, but if it fixes the audio sync I would not question it.
