Hi there.
About a year ago, and old friend and bandmate of mine passed away. A bunch of stuff was left to me: guitars, misc. musical instruments and a box of VHS tapes. The tapes are marked with names of our band and later bands he was in.
Because of this, I bought a VCR yesterday. I have an old tape and put it in the VCR and it worked perfectly.
The problem is, when I put in the tapes left to me from my friend, I get no audio or video. In fact, the TV states that "there is no signal" when I hit play for those tapes.
The tapes may have been used for audio only recording.
Anyone know what can be going on here?
				Results 1 to 17 of 17
	Did you buy a random VCR?
 Random decks from Goodwill/wherever can ruin tapes this way.Want my help? Ask here! (not via PM!)
	The vhs/svhs cassette can be used in digital audio recording via
 1. Old Technics format, rarely used
 2. Sony PCM-F1, 1610 etc format common in 80s & 90s (but actually encoded the dig audio AS video signal)
 3. Multitrack digital using common Alesis ADAT format (but should be labeled as such)
 Doubt it was #1. #2 would show what looks like digitally pixellated/blocky snow video. #3 would not show a video signal.
 Could also be that they are video but are bad/out of calibration so won't properly play. Or wrong national system/format for your machines.
	Maybe something like this ? https://www.youtube.com/watch?v=WVDCxTtn4OQ
 well if there wasn't used a camera at any time…..
 Also.. dont know if it's possible to decode the video signal with external DAC , because these PCM players are very rareLast edited by Eric-jan; 12th Jul 2022 at 20:56.
	PCM encoded tapes will display a video of the PCM pattern with a normal VCR, again unless the OP gives more info about the tapes it is a dead thread.
	Could possibly be a SVHS tape, which will not play in a standard VCR ..... Is your VCR a SVHS model?
	A VHS machine can playback both HiFi and linear audio from a S-VHS tape, and video too to some extent, except for the bright spots that clip into black strakes.
	If there's no info written on the cassette about recording format, it's hopeless, could be even wiped tapes.
	I do not know if this will help-can you post a couple of photos of the tapes? Is it possible they were recorded in /on another countries format? PAL/NTSC problem solver.
 USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
	It's highly likely that these are Alesis ADAT digital audio recordings. The format used SVHS tapes to record up to 8 tracks and multiple units could be ganged together. It was a "poor man's multitrack." You might be able to find an ADAT deck on eBay.
	Or a transfer service, https://thegreatbear.co.uk/project/alesis-digital-audio-tape-adat/ if these tapes are SuperVHS ones that is.
	That's why posting pictures of the tapes is very important, but it seems that the OP just landed here through a google search, created an account just to post the question and now he forgot what forum he posted on.
	We don't KNOW that it's not about video. Neither did the OP in the 1st post. That remains to be determined.
	Plus the OP did not respond to anyone, and not any details on these vhs tapes, next move = OP !
  D-Vhs JVC HM-DH30000U does not play tapes in pal-m?By Caius in forum Capturing and VCRReplies: 4Last Post: 30th Jan 2022, 22:06
  VCR refuses to record but plays VHS tapes perfectly fine.By golenman123 in forum Off topicReplies: 13Last Post: 6th Sep 2021, 05:19
  Dual VHS/VHS-C VCRs to play VHS-C tapes wthout adapterBy Bsmarado in forum RestorationReplies: 7Last Post: 18th Mar 2021, 06:04
  3 problem vhs tapes plus one that plays fine, but footage is shaky 8mm filmBy bbmaster123 in forum RestorationReplies: 33Last Post: 1st Mar 2021, 11:25
  Easy Capture Device Jitter on Tape Play Back VHS or Bata But DVD works fineBy Jromeot@gmail.com in forum Capturing and VCRReplies: 5Last Post: 20th Mar 2020, 19:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
