I have two videos of the same dimensions that that will play as one video. So, the starting point is two videos loaded as two layers with the same start and end point. Then I want to cut out a transparent rectangle in Layer 1 that I can see the corresponding area of Layer 2 playing through. I also want to cut out a transparent rectangle in Layer 2 that I can see the corresponding area of Layer 1 playing through. The two rectangles are in different parts of the screen and do not overlap. Also, the videos in the rectangles will appear exactly as they are in the other Layer. So, no video resizing or other adjustment is required.
Apart from the two rectangular areas, only the Layer 1 video will be visible in the playback.
I would be grateful for any suggestions.
Results 1 to 1 of 1
Vsdc
By shelley8 in forum EditingReplies: 3Last Post: 16th Sep 2020, 11:21 -
VSDC Help
By crhund in forum EditingReplies: 1Last Post: 3rd Sep 2020, 11:54 -
Vsdc
By vunopawe in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2019, 02:54 -
VSDC Stabilization
By Penny666 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2019, 11:07 -
advice using VSDC
By SteveM17 in forum AudioReplies: 0Last Post: 27th Nov 2017, 15:47
