  1. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    For starters:
    I still use DVDShrink, it works fine for me, (rip DVD's)
    On my newer computer, I have RedFox *latest version* installed.
    My sis gave me an old XP computer (it has some version of Office so's I can view *.docx files)
    I thought why not & installed *last version* Slysoft ANYDVD.
    Almost all DVD's ripped with the old slysoft s/w more than 95% are ripped with DVDShrink
    Most DVD rips with Redfox, Shrink gives an error (DVD structure, whatever) and does not work. I must rip to hdd files with Redfox.
    Opening those files with Shrink works OK.
    Its just an extra step, ripping, then using Shrink, I save as 'movie only'. This takes more time is all.
    What might be the cause of *old working better than new* in decryption & ripping?
    Just wondering, thats all.
    -corne-
    Always someone here with a good answer/explaination! Thanks
    Yes, no, maybe, I don't know, Can you repeat the question?
    Would have to see the file structure of the ripped files.
  3. It must be something that RedFox is not decrypting that DVDShrink needs to work.
    I can't give a better answer because I don't have RedFox software & I will never purchase anything from them.
    I wouldn't install RedFox if they gave it to me.
    I do have the last Slysoft version of AnyDVD HD & I also have the older AnyDVD both paid Lifetime licences.
    For all the good that does.
    They still work well on most DVD rips both with CloneDVD2 & DVDShrink.
    I also have a Lifetime DVDFab Passkey on a different computer .
    For some reason AnyDVD & DvdFab software do NOT like to be installed on the same OS.
    So far DVDFab Passkey has worked with DVDShrink for all DVD rips I've done.
