Hi,
I have a number of TLX video files which I would like to view. I have a viewer called DX-PC25E Lite which is a Mitsubishi product but I get a message saying that this App will not run on my PC. This is a standard Win10 laptop. I downloaded another copy from the net but got the same message.
Peter Martin
Results 1 to 10 of 10
Not too much info on the web about that. However when doing a search I found that software, with that name, is used on a DVR DX-2500E. If you Google TLX files it shows that that is a dictionary file. You say you have a viewer. Hardware or software viewer?
Extraordinary claims require extraordinary evidence -Carl Sagan -
looking through the specs of the mitsubishi surveillance system that used that software lists only "WIN98/2000/XP" as the operating systems that it will install on.
Hi, Thanks all for the suggestions. I've uploaded a zip file containing a sample TLX file. Maybe I just need to get hold of an old computer?
@ Treetops Yep just a software viewer
Cheers
Peter Martin -
i looked in the file, and there is data there. i'd guess surveillance camera stills. no way to tell but they are most likely password protected.
Yes, they are surveillance files. I have others which I have been able to view which aren't pw protected so I'm hoping these won't be.
I'm working on a possible miscarriage of justice case.
Cheers
Peter -
old computer is your best bet to get that software installed. goodwill? they have cheap ones.
I was able to install the program and playback the sample file in Windows XP
I need help decrypt movie files (starzplay) , files included !
By Dazzle Cat in forum Video Streaming DownloadingReplies: 1Last Post: 1st Oct 2020, 19:29 -
How do i convert .srt files to .odt files?
By jooj in forum SubtitleReplies: 2Last Post: 25th Dec 2019, 20:32 -
Batch combining multiple audio files with same picture to create mp4 files
By MD_89 in forum AudioReplies: 25Last Post: 1st Dec 2018, 23:29 -
AVI Files Smaller Than WMV Files
By tutorpros in forum Newbie / General discussionsReplies: 51Last Post: 23rd Dec 2017, 18:44 -
Need help with Mplayer to play mov files which reference to external files
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 2nd Dec 2017, 13:21
